  • Replies 123
I don't think the arguement is NA V Turbo.... It's NA SKYLINE V TURBO SKYLINE... Big difference...
And i'm sorry but people who are saying that stock for stock a gts has more on tap around a course than a gts-t can't drive... It's not so difficult to drop the car back a gear, or kick the clutch a little if you've gone into a corner too slow or braked too much.. Not to mention that the turboes on a stock gts-t spool very low.. Also, i've been in quite a few RB30E powered 31/vl's and the pickup isn't exactly great.. and the top end is nothing amazing.. definitely not the kind of engine i'd choose over a slightly lower capacity turbo'd six...
Don't bother, they don't get it.
