i also heard of this happening so i got a stainless one fabricated for me for 100-150 cant remember when i put on a Z32afm and a few other things, being stainless it looks good as well as serves a good purpose... also it stops the pod from moving so i didnt need to put a bracket to hold it steady.. didnt think the price was too bad
can anyone confirm that the stockR33 turbo will need a 3-2.5 inch silicon reducer?
Ditto, i would really like to know the same thing before i go and buy the wrong one, i just need confirmation that the stock turbo inlet is 2.5"??
Cheers
P.S, i should hopefully be starting sometime this week and will be using 3" polished alloy pipe insteas of stainless
i had my stock rubber pipe on and made 191rwkw wit usual mods + safc and gt2535 on 14psi ona r33, changed my plugs and took my stock rubber pipe in2 an exhaust place, the copied it, changed me $40, also put the small pipes for the plumback and oil breather.
slaped it on and got a retune and made 200rwkw, plugs wouldnt have made me more kilowatts, so the $40 must have made me some power as i didnt touch the engine before
Definatly agree with changing it to make it more solid. One of the guys at my work had it happening to his 180sx. He said he just fed in a steel coil spring like thing. No problems after that. But personally id go the alloy way. If your gonna go through the hassle of playing around with it u may aswell change it all together, not to mention tidy it up a bit. In my opinion the stock rubber pipe is an ugly piece of sh*t that lets that side of the engine bay down and makes it look cheap and nasty haha. Metal will make a world of differance
Finally i have found out what size the turbo inlet is, thanks NYTSKY for measuring your turbo for me :D, it is 59mm which is 2.25", so i have just ordered my 3" 90degree alloy pipe and 2.25" -3" silicon reducer, hopefully i will have this finshed sometime this week if im lucky, i will post pics of the finished product.
yes the turbo inlet is 2.25 inch,
I have fitted a 3 inch metal pipe and the car doses but not what i expected, im gonna try get a brass pipe thats 2.25 inch and see what happens.
Doses?? wtf??
And what do you mean by "not what i expected", does the car run fine or does it run different to when you had the stock intake pipe?
by dose i think he means like flutter (dose = vl talk ie rubbish)
also why would you go brass? the material used wont change sound and id rather go 3" to 2.25" it would be forcing the air in more aggressive in my opinion.. 2.25" all the way seems like a waste, i mean the outlet for afm is 3" why go smaller??
I hear that the material that the pipe is made of and its thinkness makes a difference to the fluter sound, with a 2.25" pipe the flutter should sound different which is what I want and performance does bother me because im doing it for the sound-experiment
Good news, i finally finished the intake pipe an have taken lots of pics, i made it so it fits up to the stock airobx and i can also use a pod aswell
The parts i used were: 1 x 3" 90 degree 600mm long alloy bend, 1 x 3" 45degree silicone joiner, 1 x 3" - 2.25" silicone reducer, a small length of alloy pipe that is the same size as the stock plumback pipe,some radiator hose from super cheap (i think it was the bottom hose from some triumph, it fits the stock plumback line perfectly) some old plumback line that i had leftover from when i installed the RIPS plenum on my old car,some clamps, 1 x local engineer for the welding lol
Heres the pics
The pipe was 600m long so it required a lot of cutting to get to the exact length
I had a little peice of alloy pipe welded on the bottom of the intake pipe which connects to the modified plumback line, i was orginally going to have the plumback line connect to the top of the intake pipe just like it is stock but there wasnt much room so i decided to do it this way.
How it looks from underneath the car
Modified plumback line, this was a bit tricky to make as it had to clear the aircon pump bracket and then curve underneath the intake pipe, it needed lots of cutting, rotating and welding, it was probly the most diffucult part to make work and look stock
The kool thing about it is you cant see it in the engine bay unless you have a really good look
The car runs fine with it , i have only tried it with the stock airbox at the moment and the induction noise does seem to be a bit louder, i have not tried it with a pod yet though.
Edited by nizmo_freek
That looks really good mate, I'm thinking of going back to the standard airbox like you've done. That looks almost factory if the hoses and pipe were black.
Cheers mate, i was originally going to use black joiners and paint the alloy pipe black but i cudnt find any black silcione joiners, you can barely even see the pipe/joiners ,you would never know its there unless you have a real good look.
^^^ Thats exactly what i did to mine as well...good job...only difference is that i bought the pipe with the BOV plumbback and breather fittings already welded on...which made it a pain to adapt to the standard hoses...but nothing a bit of backyard ingenuity couldn't fix...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
