Originally posted by T0nyGTSt
If you're in Syd. I can hook you up with cheap fiber bits.
Bars, skirts, pods, wings you name it.
T.
im in Sydney.im wanting an aluminium wing maybe,but definatley want the "Fibre Vision modifies TRUST front bar" its called and atm cant get it cheaper,please pm for details,thanks!
https://www.sau.com.au/forums/topic/16704-body-kits/#findComment-346731
