i am getting charged $440 for a days labour looking for the problem
and a new oxygen sensor fitted. this sounds very expensive to me.
am i getting ripped off?? does anyone know how much a new oxygen sensor is??
i like my pockets fat not flat
BS!! way overpriced.
Genuine sensor is under $200 plus 30min fitting (max) so lets say $80/hr and call it $250 all up
EL falcon sensor I got for $60 and paid an auto elec $50 to wire it in for me as the plug needed cutting etc around $110 all up
$440? did you get a small favour in the back lane as well?
Dude I just fitted a universal 18mm Zirconium type to my GT-t, it works just fine and cost $56 and 15mins to fit. Fitting just involved cutting the plug off the old one, using the supplied crimps to attach the new one.
This is the type I got, they're Highflow brand
http://cgi.ebay.com.au/OXYGEN-02-SENSOR-3-...9QQcmdZViewItem
it took them a day to figure out that the oxygen sensor was stuffed :blink: What exactly was the problem in the first place? That might straighten things out becaase f**k paying over $400 to put a oxygen sensor in!!!! My mate got a oxygen sensor from nissan then drove over to a mechanics and they preety much handed him the tool to do it himself. Obviously they saw no point in charging someone for such an easy job.
genuine is 180 rrp - trade is less. labour - you're talking 10 minutes. you don't even have to take the heatshield off.
I would feel bad charging someone to do that. I'd just do it for free - pr - encourage them to come back next time. or charge then $10 labour or something.
having said that though, you have paid them for some diagnostic time. If your mechanic doens't have a scantool, I wouldn't have got them to diagnose it though. mucking aroudn with a multimeter takes ages, and wastes your money.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
