in fact i like these brakes so much I bought another set for the other car on the weekend. 356mm set this time, with a minor adjustment to the dogbone adapter we got it to fit under our weds 17" wheels too
  • Replies 116
I just wanted to post somewhere in here that I have now had the opportunity to use the "race" pads that Just Jap sell for the G4's. I have standard rear brakes with BEndix Ultimates in there and find that not only is there no bias issues, I have fixed a bias issue that I believe the car has from factory. I was regularly cooking rear rotors and pads before but now it all runs fine. Lap times are down and the car stops amazingly. I was regularly braking far too early due to being used to the standard setup. With the addition of good tyres and these brakes I knocked 3 seconds off my previous pb at Wakie.
Thats awesome. You were quick before from memory, so you are into the 1:07s or something now? Though i have to ask, what tyres? Tyres are worth 2-3 seconds at Wakefield, so be interesting to see you run the same tyres as you used to and see if there is any difference in lap times at all. Thats not to take away from the fact that the car is much easier to stop and nicer to drive.
1:11's on new enough RE55's and 1:08.5 with old 2nd hand slicks. My shocks are totally stuffed so if I can find some money for a rebuild of them I will go and have another crack. I nearly came in my pants every time I did a 1:08 so imagine how excited I'll get if I pull a 1:07.9999999!
So you are 2.5 seconds quicker on old slicks compared to relatively new semi slicks? That goes agaisnt the trend of typical time improvements for tyres. I suspect the RE55s were cactus as i would have thought a 250rwks R34 on RE55s would be quicker then 1:11s? Slap some new suspension in and decent RE55s and i suspect you will match/better then slick times!?!?!??!?!?!
LOL, actually no. Sober at present :) Just getting dumber by the day. :P You did you say "With the addition of good tyres and these brakes I knocked 3 seconds off my previous pb at Wakie"
LOL...sorry, just saying thats huge, but with swaybars in the mix as well it starts to paint a picture that makes more sense :)
Oh damn, maybe I forgot to mention the sway bars.
From my hazy memory I was running mid 1:11's with RE55's, then high 1:11's with sway bars, brakes and streeters, then mid 1:08's with sway bars, brakes and old slicks.
  • 4 months later...
Hi all great read, r33 gtst - anyone had clearance issues with wheels 356mm kit 18" wheels tried spacers still no good might hav to get wheels machined a little, tried two sets of wheels speedy inferno 18x8, and ROH drift R 18x8.
cheers skuzzas
I've run the 365 brakes under 17" rims without spacers, so it is the design of the rims that matter not the diameter.
In particular rims with "dish" just won't clear good brakes
Just re-reading the above, i cant believe how brakes can bag you 3 seconds, especially around a track like Wakefield. I mean think about a car that is 3 seconds slower at the drags and the distance between them when they are travelling over 150km/h. I cant see any brake upgrade allowing you to pull that sort of time difference from simply slowing the car a few meters deeper under brakes
The problem with Drift Rs is that they have "cheater dish" - where the end of the spoke curves in before contacting the barrel. It's the only way high offset wheels can get any lip at all.
Roy, I believe the tyres would have had a huge impact on the time.
Brakes to improve your time as long as you use them correctly and get on the gas quicker. Your lap times will slow if you are heavy on the brakes and hard on the acceleration because the distance you are covering at speed is reduced dramatically compared to a proper entry and exit with a constantly increasing throttle.
I agree regarding tyres, but i have simply read too many articles and have fiddled with enough brake setups to confidently say that the difference is on the 4th lap when you simply have too much car for the std brakes and everything is getting toasty hot
The only major improvement i think you see with bigger brakes is consistancy. SO a 3 seconds over a number of laps i can easily believe. Over a single lap, being your best lap of the day.... well i am just still a little sceptical of such claims.
Suspension setup and tyres play a bigger role in stopping distances then the caliper/rotor arrangement. There are many back to back tests that show stopping distance improvements of less then a car length from std equip using good pads and fluid compared to big dollar Brembo/AP/Alcon setups. Where the big setups help is that they operate at lower temps so are more consistant
  • 4 months later...
Any idea if they will be able to be run with 33 gtr wheels + spacers? Or am i better of getting the 330mm g4 set-up? :down:
cheers
Grab the 356mm setup and if your 17's dont fir then get some TE37 or something that have better brake clearance
So your saying go for the 356mm set-up, the 330mm doesn't really add up as an effective upgrade? I was hoping to not upgrade the wheels, everything adds up so violently.. motor, turbo, fuel set-up :D the wallet.
Going to measure the diameter of the wheel today, hopefully that's all Il need a 20-30mm spacer should stop it from hitting the spokes (as it's not a dished rim the spokes are set out more to the outer edge of the wheel), will report my finding
In the grand scheme of things the 330 and 356mm setups are pretty similar in price. And considering you have a big heavy GTR with plenty of grunt i think you are really better served with the 356, especially since there is a range of 17" wheels that will swallow them. Just need to flog off your current wheels to help fund the better 17" wheels.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
