Thanks Roy, might just have to wait till the car is back out of the shop before I dive into another aspect of the car. Will keep everyone posted.
Edited by Tomek
  • 1 year later...
  • Replies 116
Duncan any chance you have tried to fit 17" drifteks over 356mm fronts?
I am seriously thinking about getting a set considering
R33 Gtr calipers say $1800
new discs $700
pads $300
braided lines $200
=$3k
And I think I have found a place that will do 356mm + 330mm kits delivered for $3000
mods? not sure what you mean?
I have a set of 356mm on the 350z (well did, I just sold it) for about 2 years, straight bolt on, no problems.
I have a set of 356mm on the new race car but it hasn't run yet. straight bolt on.
I have a set of 330mm on the stagea under 17" rims. These have been running for at least 3 years and are second hand off my race car. 3rd set of pads, first set of rotors, absolutley no issues. I did have a minor issue with installation, it is a 32 gtr kit with m12 bolts but the stage hub allows m14 bolts. Added a small sleeve. Also had to trim the brake backing plate.
aleks, sorry not sure but you would need VERY generous internal size to run 356 under 17s. The only one we got to fit, and only by 1mm was a set of weds. Also required adjsutment to the caliper mounts and the caliper, but it was a race car so who cares. In practice....330 17"+, 356 18"+
  • 4 weeks later...
Great read. I am considering going down the brake upgrade path myself as i encounter fade on my weekend mountain runs..
What is a 356kit actually worth? And i also plan on upgrading my wheels to 18x10 +18 all round Work XD9's, i know these are the "dished style" of rim.. is anyone running a 356mm on these wheels?
What are the chancing of these clearing a 356mm kit front / rear..
Also best place to source these? Just jap?
Cheers!
  • 8 months later...
I have done a bit of research on these Taiwanese big brake kits and it appears that they are not all the same... although they have the same origin (an old AP design)
At least in the case of K Sport they are an independent company that make a lot of budget motor sport parts and has put in a lot of their own R & D into these brake kits.
In doing so they have developed a better performing and higher quality product than the others.
In the UK and Europe heaps of people use these K Sport big brake kits on serious track cars and rave about them... even after swapping over from Brembo's!
They are also supplied there and in the US by very reputable brake shops who would not be risking their reputation by selling crap brakes.
I have just ordered the 8 pot, 330mm kit from JustJap at a very sharp price; in fact only a couple of hundred more than a 330mm, 2 piece, rotor upgrade kit using OEM calipers!
Apparently the pads they come with are pretty useless but they are a standard pad size used by AP calipers and I have sourced some decent ones locally already.
Will provide some feedback once I've hit the track but bang-for-buck these K Sports cannot be beat.
Cheers Checkbuzz
Did you uncover anything interesting about the PB kits while you were researching the K Sport kits?
Does anyone have any experience (good or otherwise) with the PB kits?
K-sports/D2 are all the same dude as they come in exactly the same box and so on. You'd take a fair stab it's the same factory.
Do you have hard evidence to suggest otherwise?
Hope you didn't pay too much though (PM me the price if you want). The KSport GB i've been trying to get off the ground looks like it might almost be possible :D
Either way they certainly cannot be beaten for the price.
Scotsman recently did a 1:19 around Sandown with 320rwkw or so and those brakes. Obviously with uprated pads. Proof is right there in my books and he's done a number of track days now without an issue
It's basically the same deal as our Wilwood kits. They are not ADR approved (most overseas brake brands aren't - GREX, HKS etc), however can be engineered/mod plated if installed properly and legal brake lines used.
Yes there are a lot of peeps running K-sports here in the UK.
I upgraded to R33 Brembos though because they fit my needs of casual track plus they look better. ;)
Ash is right.
I actually did a lot of research into these prior to doing the Wilwood group buy. I even got in contact with one of the guys in Taiwan that sends these kits out.
From what I found they all pointed to a couple of factories in Taiwan that manufacture brake kits.
Suppliers than sell them under their own name.
There are even more brands (heaps more) that none of you guys would have heard of other than the commonly available G4/D2/K Sport that they trade under, such as Nashin, Kido, G force, JUN etc (see pic).
Basically if you ordered a certain quantity as a supplier (for example 15 kits) you could get what ever colour, style of caliper and writing you wanted on them. Even some different choices in rotors. So for example white calipers with SAU written on them :P They could even do a 12 piston caliper kit with 400mm x 36mm rotors!
If you knew the prices of some of these kits in larger quantites you wouldn't believe me.
I even spoke to one of my mates about getting money together and designing our own kit to supply in Australia - but we weren't to keen to send $15,000+ to Taiwan lol.
At the end of the day it wasn't something I was interested in but the proof is in the results, they work well.
They are cheap and nasty but if they do they job ok I suppose that is ok?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
