I have for sale the brakes off my R32 GTSt.
For sale are the following items:
Calipers
Front 4 piston (alloy) that are in great condition, were rebuilt and HPC coated, incuding pistons to reduce heat transfer into fluid.
Rear 2 piston calipers (alloy) that were rebuilt, though not as recently as the fronts. Were painted black but paint all but worn off. Paint was nowhere near as durable as HPC coating
Pads
Fronts - Ferodo DS2500s. Have done three track days (approx 25 laps total) and less then 2,000kms of street driving (new price $296.00)
Rears - Race Brakes Comp 2s. Have done 4 track days and approx 5,000kms. (New price $220.00)
Both sets of pads still have plenty of meat on them.
Rotors
Front - Near new 324x30mm DBA 4000 slotted rotors. Are normally replacement rotors off R33/34 GTRs. Have done 3 track days and less then 2,000kms of street driving (New price $450.00)
Rear - Near new 297x18mm RDA slotted rotors. Have done 3 track days and less then 2,000kms of street driving (New price $255.00)
Adaptors
Adaptors to allow you to run the 324mm front rotor with std R32 GTSt calipers. Machined from billet alloy. Have used these brackets extensivley on the track and there is no issue with regards to their durability. (Replacement cost for brackets is $800 less rotors, so around $350.00)
Asking $1100 ono for the pads, rotors, adaptors and calipers. Will include front and rear braided lines for another $100. Far cheaper and in better condition then 2nd hand GTR brake setups with essentially the same ability to handle thermal loads and essentially the same braking force (Pistons in calipers have slightly less surface area)
Will consider splitting gear, but really would rather sell as a kit for a guy wanting good brakes for the track. If you dont want all if it then maybe you can flog off what you dont need.
Front rotors - $350
Rear Rotors - $150
Front Calipers, pads and Adaptors - $600
Rear Calipers & pads - $250
Front & Rear braided lines - $170
More pics will be available after the weekend.
https://www.sau.com.au/forums/topic/167397-324mm-brake-upgrade-for-r32-gtst/
  • 2 months later...
Price is negotiable and will throw in braided lines to boot. Its a good budget upgrade for a GTSt, much cheaper then a GTR Brembo setup with what you can bet on beign rotors and calipers in far batter condition then you woudl expect buying used GTR Brembos
Bugger. Was hoping these had sold by now. Previous buyer pulled out after buying R33 brakes.
Willing to sell rotors and brackets so you can use your own caliper. Happy to sell calipers by themselves. They are sitting around doing nothing so best someone get use out of them
  • 1 month later...
i put the brakes back on the car as i didnt want to trial the new setup at a rally i was entered in. Problen is i cracked a rotor...good thing is i replaced them with brand new DBA4000 324mm rotors. So the kit now has rotors that have done some motorkhana work and a few laps of Winton and Sandown and less then 500kms.
Had a fair bit of interest but no firm committment. Will let the rotors go for the same price if they are bought as part of the front kit.
Any idea if this will fit on a 200ZR???? Cause I need new brakes but farked of I know what will fit! lol
I'd be looking at the whole setup if it does :closedeyes:
i got a 6/93 GTR R32... interested in front rotors... fit? im assuming so lol but always better to ask..
best price u can do? and location
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
