Have bought too much gear and need to sell the gear that i dont currently have a use for.
The rods are still in all their original air tight packaging and comes in box that has only been opened for inspection. The box has had some water spilled on it, but its only the packaging/box that got wet.
Rods come with ARP 2000 bolts and are ready to go in.
Asking $630 for pick up :P (Can arrange interstate courier at buyers expense)
https://www.sau.com.au/forums/topic/167399-eagle-rb26-rods-price-drop/
  • 8 months later...
  • 1 month later...
Sorry guys, i replied to your pms etc saying that they were no longer for sale as i thought my mate or i would actually get use out of them. But both our motors are still in one piece.
So, these are back up for sale. Clearing all the crap i have for this one day , maybe never motor and sticking with the RB20 for the forseeable future as track work is not really on the cards for this year.
So, looking for $630 + delivery using TNT Road Express
Bump...have plenty of other stuff too, like std balanced Rb26 rods with ARP bolts that were out of rebuilt engine with only a few thousand kms on them. 87mm Arias RB26 pistons, RB26 block etc. if someone wants this stuff then they can have it :D
I have a set of fully prepped GTR rod with ARP bolts.Would you consider swaps for the Eagle with cash your way?
GTR rods have been shot peened,balanced,close honed and small ends replaced.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
