Hey guys ..
Just put a new pod on my car, Seems to be getting more air (sounds like the filter is going to suck itself in) but a feel like its less powerful .. For the people reading its an Apexi Power intake..
The only real way to tell is to put the box back on but im to lazy to do that..
Can someone tell me im imagining it or its for real?
Also I need to link a cold air intake to the pod .. with the stock bar its pretty much impossable .. any idea on a way to get some hosing in there?
Currently using the stock intake funnel from the air box (im running no CAI presently) CAI will go on soon though .. just looking for a alternative to stock feed (im imaging its restricting air flow? fill me in tho!)
Edited by DECIM8
https://www.sau.com.au/forums/topic/167448-gtt-with-less-power-with-pod/
Well I can feel the power loss when I wack my silencer in! But from what ive heard thats about 20kws .. rumour ..
Maybe im just crazy hey?! Maybe in not dragging the gears out enough. ill give it a thrash tonight on the freeway ..
thanks for raising a good point .. seems im losing it
Edited by DECIM8
It came with an airbox for a reason.
Does it idle a little rough? Got heat-soak? CAI will help, but a box around the pod with feed/s will be optimum if you want to keep the pod. I'm assuming you only use the pod because it sounds tuff? Otherwise, just get a high-flow panel.
Well I put my cai on and yes it works alot better I noticed on longer drives to work the heat soak would kill the power and dumping it in second felt like dumping it in 3rd.. not kewl
CAI on and induction is actually louder but im using the stock feed from the original air box .. seems to work well and cant see a reason to do a direct feed.. when I get a new kit ill direct feed to the "GTR look like gap" that will be formed and meshed which should increase flow conciderably.
cheers for the help
Shouldnt you reset your ECU when a pod is placed on? As you have changed the air volume being sucked into the car, the ecu needs to reprogram it self for the more air.
Try resetting your ecu, by disconnecting battery.
Hope that helps
well mate ur definetely sucking in hot air from the engine...
id definetely recommend puttin in a box for it
as for the air ducting, if u have put in a front mount intercooler then u would have a hole from the standard side mount for the hose
You're imagining it.
I dont think he's imagining it. His just sucking in hot air from the engine bay which is creating heat soaking hence lower power!!! nothing beats the stock air box!!! you want some induction sound get a fmic.
Hahaa i got an apexi in the 34... and mann it sounds and feels great
I think the best way to fix this heat soak prob is to box it up and have the stock feed still there going into the box... but i wish there was another way of getting another intake pipe to come from under the pod but there aint much space is there? any ideas? pics?
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
