so for a while, ive had this wierd grinding that has come on and off here with a strong humming. lately it has got worse and worse, so eventually i popped the boot and listened to it on idle and as i thought it was coming from the pick up where the fuel pump is.
now i had just recently replaced a f**ked stock one with a bosch 040, even had it installed by boostworx whos a very reputable shop in SA, so its left me puzzled as i have bever heard of one of these failing before. now ive gotta go have a look for the warranty papers :)
https://www.sau.com.au/forums/topic/167602-a-bosch-040-failure/
Hey Stew,
Are you able to describe your setup? Is the 040 where the stocky was? Same pick up height?, sock filter?
Mate of mine had a few let go in his 180 recently. He had heaps of crap in his tank tho lol, might be worth a look.
I'm thinking of late, this is how many die, and how they are getting such a bad rap :D
no. there just shit. lol ive turned blu in the face telling people they just dont work.....
cold ok. hot gay.
Im not sure what hot gays have to do with it, but as long as industry continues to use em, so well I :D
Hey Stew,
to be honest i do not know as boostworx put it in. i can pull it out and have a look if need be. boostworx are a reputable workshop, and it seems to pick up as much as the stock one, if not a bit more.
lol.
yeah i replace them for the fun of it do i???? ever put a fuel pressure guage on one from cold to hot and see the pressure drop down to 10 pound when the fuel heats up? if not your driving a time bomb.
but its ok. you simply turn it off and re-start. and wait for it to start cavitating again.
it was kind of a piss take after how many people always reccomended them saying theyd never had one fail etc.
the pumps themselves dont fail. the way they are mounted is important. if they recieve any sort of air bubble then they cavitate and loose pressure. they still work but they dont operate in fuel over about 30degrees
besides they only put out 10% more than a gtr pump.
To start with, if you didn't have the tank removed and cleaned...and can show proof, then no warranty will be had. Also...who said the pump has failed. Just because it makes a bit of a noise. I have used a fair few of these before without failure on a single one. Doesn't mean it can't happen but it's highly unlikely. The noises can quite possibly be coming from the standard mounting frame which the pump will vibrate against if it has no padding between itself and the pump. Also if they are mounted too low they can vibrate against the bottom of the tank.
Noise doesn't mean stuffed.
yeah. like they dont fail there output just drops off as the fuel heats up. happent to me and 3 of our customers. they pumps them selve ae fine. they just went operating properly.
kinda hard to explain with out a 10 min long video showing exacly what gos on.
th o44 is a gem. no dramas regardless of mounting style
(lol @ spelling,dialing wand needed)
Shaun measures the length and sets them up correctly. So yes.. Exactly the same height as stock.
Bosch pumps do get groany when the fuel heats up. When mine wasn't receiving full volts it was so bad the floor pan would vibrate and could be heard/felt over the radio.
yeh, i read the warranty, bit annoying.
i used a question mark in the title because i was asking a question, i wasnt stating it had failed. it still seems to be working, although i have noticed some stuttering, but in saying that i have fitted an RB25 turbo recently.
its been a deteriorating issue, it has been getting worse over time, now considering i have driven in 43' heat and not had this problem, but now driving in 20' heat and having it worse than ever doesnt seem to make sense. the noise happens here and there, not every time i drive it. happens when its cold (just reached or a bit below operating temp), hot, doesnt matter.
the humming is one thing, but the loud scraping noise is a bit of a worry.
ill take it to shaun and see what he thinks, if its just the noise, im not fussed, but when i hear something like that, i want to make sure im not going to have to be picking up pieces of my engine any time soon.
went to turn on my car today, turned the ignition on, but didnt hear any fuel pump buzz like usual. so went to crank it over, started terrible like usual, did it again and gave it a bit of throttle and it made it. turned it off, tried it again, no fuel pump buzz, cranked it over again, started just as bad again (which is unusual), kept repeating this and never heard the fuel pump buzz, not sure whats happening. the noise wasnt very prominant, but like i said, it happens here and there.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
