  • Replies 82
Fine with me, I just hope a Thursday night is better for parking there...
Lack of decent parking FTL!
There's a church across the road on Mowbray road side that has a rather large carpark down the back and theres always a number of us parked there. Bit hard to spot the driveway at first but once you've seen it once you'll know what i mean.
Is that the one opposite where the beer garden is? Cool, thanks for that.
Awesome have add you to the list :)
Funny how we havent bumped into you before then ;)
I can taste the steak already.... :)
Sweet, looking forward to a good night.
I'll have whole grain mustard on mine thanks >_<
Edited by StageIan
How can I refuse this..........................I cant, cause thats my usual thursday night watering hole.
See you all there :)
HHmmmm another one who claims the Great Northern as a local watering hole.... I have actually met another Ian up there too... will find out next Thurs :happy:
might have to make an appearance
Awesome...are the loose pants comin out?
With the SNS meeting on Friday I can't do them both. I'll have to drop out of this one. Sorry - have fun for me...
Thats cool I understand :P
Just moved down to Sydney last week. Would be good to meet some other enthusiasts down here. I'll prob be the only one that doesn't know anyone there, but count me in.
I tell you your roads down here are ... !? Feel every bit of it too.
Hopefully some of u can give me some pointers on where i can find some nice roads (Equivalent to Sunshine Coast Hinterland, for those who have been to qld).
