every late model mercedes i've seen has a personalised number plate that makes no sence...
last couple i saw had 8-8888 and HHM :D
would these actually have some meaning to the owners or do they just have way too much spare cash laying around and want everyone to know about it?
yeah its late and im bored.... :action-smiley-069:
Edited by R-SPEC
My g/f's parents ones are their initials followed by insignificant numbers. A thought, when they had thier's plated up from new, they just said to the dealer that it must include their specified letters but werent fussed about anything else so ended up with random numbers, possibly the same reason as the ones you have seen?
If you work in richmond you will see alottt of these.
Generally they are on mercs and stuff, but occasionally subaru's will have them but yeh, they basically consist of random numbers, normally set up like 878 787 or 121 212 , always the same 2 numbers in a sequence (occasioanly some like 878 121)
I don't get it i just assumed it's a rich person thing
yeah always see mercs and bmw's with 868 868 etc plates. see alot with euro plates aswell. but these are just weird...
remember seeing a black merc with [ 1 ] lol now thats a good number plate.
8 is lucky number for asians...
she wasn't asian though lol
oh, saw a commo with ONPAROL thought you could only have up to 6 :D
indeed. twas vic plates though.
must have read it wrong
tehy say taht we raed olny the fsrit and lsat lteter of a wrod and can dcepiehr wthaveer it is mneat to say.
maybe ONPROL or ONPARL
no vic places are 7 characters
Ferni - yep, plates still on an F360. I know him.
BTW - Snows and I saw a new Euro plate V MB 666 on an SLK 55. Cool plate, cool car. Also, a customer has 25 on his SL 55 - cooler plate, cooler car.
See... they are not all bad.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
