nissky,
If your willing to lend me your car for a session I can make sure that your rears don't make it home if you like!!! (Jokes)
Will be good to have you along... another member of Team Track Day... Welcome.
Jamezilla,
Will be also good to have you out there... make sure that you bring some long gear and $20 so that you can go back down to Melb and brag about how you have been round EC in a skyline... you don't have to tell them it wasn't yours and you weren't driving!
Will update the thread as soon as I look at my bank balance, visit the forums, and your money has arrived people that have just deposited.
Dan.
  • Replies 184
Silver,,,it's a bit hard to explain but yes slotcars do have brakes,,,It's all about your motor's torque and braking only comes into effect when you get right off the throttle,,,,Ha Ha I'll be doing a lot of that on Thursday.
Dan,,,any chance we can get them to cut 8 slots in the track,,,,.
But seriously,,,,what time should I get there and if it rains (Please NO) should I use my street tyres. Duncan HELP!!!!!.
Neil.
7:30am - Arrive early so u can choose your garage and get yourself setup (remove any loose items, change tyres/brakes, etc, etc).
8:00am - Marshalls will check over your car (well walk past and look at it pretty much).
8:30am - Drivers briefing (everybody must attend) and that takes about 15-20mins.
9:00am - First cars will be on the track (group 1 - ie most experienced/fastest).
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
