Perhaps try another coat of fresh paint on the rocker covers? ;)
I must say I've read through your specs list about 5 times now and the one thing I can't help but wonder is why you are only running 14psi?
the reason why i have not raised the boost anymore is because of the standard 444cc injectors as turning it up to 16psi saw it hit above 90 duty cycle
and jim said that it's best to run it safe so he turned it back down to 14psi
post up your IGN and INJ map
just view on the hand controller and punch it into an excel spreadsheet
should take you 5 minutes
then we can see your maps and see how its tuned
will give away lots of info
how do i do that???
Cheers
anthony
You have a half baked setup
So expect half baked performance.
Until you get the accompanying mods to the turbos, then expect sub-standard performance from the setup.
Your chasing a problem that quite frankly doesnt exist.
The turbos are not "too laggy", they are working as you would expect with only half of the supporting mods.
Get the parts onto it as listed by Beer Baron and go for a proper/decent retune.
If you dont, then revert back to standard turbos as thats all your supporting mods are really good for
main menu
SETTING
IGN MAP
then youll see a 5x5 view on the 20x20 map
so write those numbers down into an excel spreadsheet
then scroll to the right 5 times, so you start at row 6 (look at the top row for the row #)
and then keep doing that
until you cover all 20x20
With head porting and the ACL's you are perhaps well under the stock compression ratio? Do you have the CC's for the head and spec of the ACL piston used?
With a lower compression ratio you will drop the bottom end power off a tad and you will need more boost to make the same power. There is a little bit of swings and round abouts when you throw in head porting but, what the car is really needing is a set of camshafts for turbos that size.
You obviously also need to have some split dump pipes, I didn't see them mentioned. If you don't have them with those turbos you are looking at a bottle neck. The other thing to ensure is that you port matched the exhaust manifold for the turbo's exhaust housing entry.
600HP turbos should be matched with head work, cams , intercooler etc.. from an airflow perspective. Just like a turbo's map there is an island of efficiency for each of these components. Attempting to have them line up will always net you a faster and more responsive car.
You have lots of the good bits already but, bottom line is throw some injectors (700cc sards aren't bad), dump pipes and cams into that setup and it will be a very different animal.
Hi nismoid
the reason why this thread was started was to see why the response i was getting from my turbos was different to other peoples experiences with similar setups even with bigger turbo's. Maybe you should use the search function and see how many people who own GTR's have a similar set up to me i.e no cam gears, they have injectors and are running higher boost but that fact doesn't change boost response which is what i was asking about. As you can tell i have done a search on it!!
and thanks for all your helpful responses
Cheers
anthony
Edited by black sky
Thanks for the reply. See i bought the car with all these mods done to it, i have the receipt for all the work that was done but i'm not to sure on specific details. but i just expected a GTR to push me back in my seat hard especially with 250 AWKW but it doesn't. i already have the plans to change the injectors and install cam gears but my power goal of 320-350 rwkw apparently doesn't need the dumps to be changed ( that's what my tuner says's) but i would love the increase in response if it would make a 300-400 rpm reduction in lag. And i really don't have the funds to install cams unfortunately i know that would make a huge difference but i spent all my money buying the car in the first place.
just on the note of cam gears, what cam gears should R33'ers with a GT30R turbo be looking at in terms of getting a bit better response? series 2
Edited by Pauly33GTS-t
Cam gears are cam gears so you don't need the expensive jap brand cam gears as they all do the same job and they are interchangeable amongst the RB family so rb20 cam gears will fit rb25 and rb26 as well. not to sure about the rb30 though. Hope this helps
Cheers
anthony
Hi nismoid
Cheers
anthony
Like i said, half baked = poor results.
People with even bigger turbos wont be running them in a stock motor now will they?
All you are doing is running very large twins on a stock motor (for the sake of this conversation)
Head porting & exhaust, somewhat to do with it, but thats it.
Everything other item you have listed in your first post basically has nothing to do with response/power.
So direct comparison is utterly impossible until you start to match the parts everyone else has
As ive told you, apply some lateral thought to this.
1) Your not running half the parts everyone else is running, and they are using smaller turbos in a lot of cases
2) Your experiencing average performance
:sorcerer:
Item 1 & 2 are, funnily enough, directly related to each other.
:sorcerer:
For the fact your running those turbos on essentially a stock head, capacity RB26, those results are as good as you can expect
If you have spent all your money for now , my advice is to leave the car alone and just keep it well serviced. A substancial increase in power will cost you in a substancial and on-going manner. 350rwkw is a fairly expensive proposition to maintain.
I think you need dumps if you don't have them, you will make more power.
14psi isn't much boost for N1's , that power isn't really shabby for the boost, they like to live at 18psi or so. If you add some cam gears you ought to be able to tweak the power curve.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
