hi all,
Ive just noticed the last couple of times i drove my car it was difficult to select 2nd gear. the clutch isnt more than 1 yr old and the gearbox was rebuilt 11 months ago. im not too sure if my clutch is on its way out or not. i do drive hard sometimes.
how often do i need to change the gearbox oil and soforth? 5 speed manual r33 gtst. exedy organic heavy duty clutch.
need advice.
thanks in advance :laugh:
https://www.sau.com.au/forums/topic/169125-hard-to-select-2nd-gear-when-cold/
hi all,
need advice.
What gearbox oil are you using?
Could it be due to the weather cooling and the oil thickening?
How old is your slave cylinder? (underneath on driver side of gearbox)
I fitted a new slave cylinder, fresh clutch fluid and had it all bled and it was like I just had a brand new clutch fitted, that's how big of difference it made.
If you havent got it already, try putting synthetic oil in your gearbox. Synthetic oils perform much better a low (and high) temperatures than minerals. I havent had any sticking since i switched to redline light shockproof in my tired old box. Shockproof is not suitable for a recently rebuilt box tho.
gearbox was built from scratch 11 months ago. i'l change the gearbox fluid and clutch fluid n see how it all goes
11months is nothing. It should still be perfectly fine unless your master or slave cylinder is bleeding off a little resulting in poor travel.
Not saying this is the case in your circumstance but I had a gearbox rebuilt for $1200 including in/out labour (VS 5ltr 5speed) some years ago as first gear was popping out and I didn't have the time to do it myself.
I requested everything to be replaced, all bearings and syncro's as the box had a little layshaft rattle. (I've rebuilt box's before I know what sounds are coming from where)
Upon receiving the gearbox it still had the layshaft rattle; I questioned the people and they told me it was a load of crap and couldn't hear the layshaft rattle when it was as clear as daylight. He also told me they send the gearbox's off to a specialist to rebuild. So that was that.
A few months later at a party I met a bloke and we got talking. He mentioned they do the gearbox work for the mechanical shop that I had do mine and that he remembers doing a vs 5ltr 5speed gearbox box BUT it wasn't a full rebuild; it was only to fix the first gear (he said it was just a pin that dropped out) and replace syncro's. I return to the work shop and find they have gone bust...... :)
So screwed.
90% sure it's your gearbox oil guys. I got some Motul gearbox oil put in mine and I started having the very same problem. Switched to Red Line Light Weight Shock Proof and I couldn't be happier. No problems now whatsoever. It's not recommended for newer boxes though.
Talk to a mechanic that works mainly on imports and they all recommend it.
Talk to a 'gearbox/clutch specialist mechanic' and they tell you it's a not as good as everyone thinks. I had 1 good local specialist mechanic show me the internals of 2 gearboxes that he was working on. The gearbox that had Castrol oil was nice and clean, the redline gearbox looked like someone had filled it with grease, not oil.
Each to their own I guess.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
