There's 4 very good write ups with pictures on this site. Everything is in them.
Take your time and take mental pictures or physical ones of everything you haven't seen before or are unsure of as it will help when putting it back together.
have the correct tools handy. Get a balancer puller that uses the two m6 holes to pull it off.
Melbourne, Northcote area. I have had a look at the step buy step procedure, I guess i am just not 100% in lining up the timing belt marks.
You'll be fine :) it's so simple. Wind it over and watch the cam marks and that they align, then check the crank. Done.
Question, once I have aligned the the marks for inlet,exhaust and crank, i then remove the tensioner, once the tensioner is removed / released ,will the belt want to move the cams from the original set location because of the tension lost ? if so how is this avoided or rectified?
one other question, just to clarify, the harmonic balancer retaining bolt is L/H thread or R/H?
Balancer bolt is normal thread. Righty tighty lefty loosey. There are a few ways to undo it.
Cams won't move, they're locked.
I'd advise looking at all Diys we have on this website and getting a good idea on how to do it.
Maybe someone here who is close to you can come and help too
People tend to stuff up the tension, usually too much.
Definitely do camshaft seals, and crank seal.
Yep I did, I guess?.
The gates belt is a LOT stiffer than the genuine and dayco belt, so at the same tension of the original, the gates felt a little loose. I did it up a bit tighter and it whirres
Just a quick question fellas,
I changed the timing belt on my r33 s2 det last night, all went reasonably well.. This morning i took if for a drive and every thing seemed fine until I entered the freeway and opened it up a bit, as load and pressure built up above 4.5-5 rpm + It seemed to bet a significant loss of power, now I would also like to mention that I have upgraded the turbo due to the turbo spitting it self the other day, the up grade was from standard - to a Garrett T3/T4 Hybrid A/C CHRA Conversion. (Car not tuned yet)?
is it a possibility the crank angle sensor could be 1-2 mm off even though i make it? or is it just running very rich etc..
I know this is not the right topic , a link to the correct topic would help or some insight would be appreciated.
Edited by Antek
I don't know much about that turbo. But have been in a few skylines with upgraded highflows and bigger turbos without tunes and they are slow and shouldn't be driven hard until you get a tune.
Did you mark the cas before taking it off?
Should check your timing with a light anyway because no mark will get it back to spot on. A small movement on the CAS is big in degrees, you could be up to 10' out? And that makes a huge difference as well, even 5 is easily noticeable.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
