  • Replies 70
Anything that changes emissions (FMIC, turbo back exhaust, ECU, turbo etc ) has to pass the emissions test and be engineered as it was passed. Only if you have a catback exhaust with no FMIC can you just use the DB test to engineer the exhaust. All exhausts have to do the DB test to be engineered. Can you tell I have extensively looked into this......lol!
So if you detune your car to pass emissions due to aftermarket ECU... get a pass.. get it engineered... then change the tune.. its not valid. Once they stick the gas analyser up the exhaust you are going to get raped over the coals. Also if its something with a controller.. the tune/ecu... boost, etc it needs to be locked and the controller removed from the cabin in order to meet the engineers certificate. Although not sure how often that kind of stuff gets picked on???
To engineer coilovers.. the engineer must set the coilovers to the minimum height (100mm @ lowest point) and then destroy all the thread underneath so as you can't lower it once its been passed and recorded on the certificate.
FMIC still need to be passed (ie installed when test was done and not after) EPA but also the REO can't be cut, nor the hole in the guard be below the structual seam. I never thought that they checked this until a friend got pulled over the other day and they actually got on the ground and looked under the front bar to see if the REO had been cut in any way!
Pods... as long as its enclosed completely they are ok... although Moanie's post is a lil worrying! I asked the RTA directly at the inspection station as well as my engineer and was given the ok????? Unless the rules have changed in the last 2 months? Mine is listed on my engineers certificate only because it was the only thing not on there they might have tried to pick on!
I believe i was taken to court by the EPA, only because I was a repeat offender. Don't see why they would do that if you had an engineers cert! Wuld be worthless if they did!
And damn! alot of research! I need to look into engineering mine now! *sigh* so many expenses!
Mona theres a guy in peakhurt who does engineering and is really good.
Search button doesnt work for you or what?
http://www.rta.nsw.gov.au/cgi-bin/index.cg...FormButton.y=12
DIF, I did use RTA search and yes I did find that. That is the REASON why I made this post to clear things up.
yeah dont worry about it man... your thread just seemd to be the climax of some shit thats been waiting to drop...
i dont think anyone meant to scare you >_<
and dont be afraid to come back either :)
Not being a bish or trying to start anything Liz, but isn't that the pot calling the kettle black? >_< I can recall many times you have done exactly the same thing. Everytime someone asks a question that has been asked may times they get the same "use the search button" off any number of different people - why is this time any different?
The guy mentioned he searched SAU (not well as this was brought up less than a week ago)... doesn't look like he searched RTA site too well either... Corinne provided a link to answer his question. Soooo as far as I can see... she actually provided RTA rulings and not just hearsay. Smoky had the answer correct and Corinne showed the guy where to find the demerits on the RTA website to confirm Smoky's post. If she was being rude there would be no link.... just a "use the search function".
Just my 2 cents.
PPL FFS! I freaking searched both sites alright. Reason I made this post is because I am paranoid about losing any points, I have 2 more months to go before I get all my points back so I dont want to risk it. Plz note, one of the guys I spoke to about this was telling me how he LOST his 3 points cos of the pod defect and now he only has 1 point left etc etc. So the first thing I did was search RTA and SAU was second. I dont give 2 toss about the fine as long as I dont lose any points.
hi mate.. have you been defected already and your not sure if you lost the points?
or you are just worried about being defected and then losing points?
hi Sl!m,
I havent been defected. I am not worried about getting defected, to be honest with you...if the defect fine for having a pod was well over $500 I wouldnt care less but losing points is what worries me.
I am on a limited amount of points atm >_< so thats my major concern.
I search RTA and SAU, RTA said nothing about a fine and SAU basically talked about a defect fine. From what I was told at the Toyo Drags, this thing only came in recently and the group of guys I was sitting with all agreeded when one of the guys outlined that defects will cost u points now.
I was hoping to find something on RTA which actually outlined that having a pod is a defect and wont cost u a demerit point.
I know what you mean its a awesome noise, How good are you at fabricating ?
Or know anyone that is?
I only recently starting playing with fibre glass when I restored my boat so I guess I am not too bad. A mate of mine today told me that "WestSide Mufflers/Exhaust?" near bankstown actually sell premade airbox for pod setups so I might check that out before doing anything else. The price was reasonable too...I think it was about the $80 mark.
hi Sl!m,
ok cool, thats all I wasnt sure about. wether or not you have already been defected and wanted to know if points were to also be taken (or really given as you pick up points you dont really lose them, once you gain a certain amount, then you lose your licence) or if you wanted to know if it happens in the future will the points on ur licence be affected.. now that that is cleared up.. lol
Your best bet would be to send an email to the RTA, they have contacts section and ask them the question, also ask them for links to prove the information as some times it can be contradicting.
But I think Smoky or Corinne answered the question in here, but getting the answer from RTA wouldnt hurt.
cheers
Oh well there you go >_<
Thats a pretty good price and I still think you would get the induction noise just not as loud maybe...but better to be safe then sorry :)
if you can get a airbox for $80 go for it.. I have a custom one myself, and you dont lose the induction noise just becomes a little bit quieter. >_<
just check that it all lines up.. after market pods etc are not all the same, so whatever they measured to pre make it, may not be the same as what you have under your bonnet :)
no points - well unless its one of the 3 listed below.
There are 3 which can receive points straight away - defective seats, steering, & seatbelts.... all with good cause too!
Sorry .. Does steering include a aftermarket steering wheel? I.E no air bag?
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
