  • Replies 113
Popular Days
i am.
f**kn over it. Everyday there's a new argument.
too many touchy kunts around.
go on, now bitch about me, i know you want to.
i agree, i wont be surprised if im the new target cause of this thread, but what i have said needed to be said!
Its about time the individuals that continue with it grow up and act their age.
The standard of SAU as a forum, particularly the NSW area, has really dropped lately due to the complete lack of maturity that a few people have persisted with and it sets a pathetic example for new members finding their way onto the forum.
well said!
exactly.
people keep finding new things to cry about everyday, then get others to side with them and gang up on others.
wtf is this, fkn primary school? act your fkn age.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
