  • Replies 74
Posted Images
Are you guys receiving emails ?
I just reread this thread, I thought the problem was that the subject wasn't correct in the emails, but maybe its that you're not getting them at all?
yeah subject has changed but still isnt correct
OLD
Subject: Topic Subscription Reply Notification ( Skylines Australia )
NEW
Subject: Subscription Reply Notification | ( Skylines Australia )
notice the addition of the |
  • 3 weeks later...
hehe. took a while, sorry bout the delay.
oh also added the topic ID to the end of the subject, so if you want to create email filters, do it based on the ID. just in case the subject changes, you don't want the filters to not work.
ummmmmmmmmmmmmm did you just make a change? The first couple of emails I got this morning were fine, and now they all come through looking like:
Ska,\n\nMadaz has just posted a reply to a topic that you have subscribed to titled "Pm Email Notification".\n\n----------------------------------------------------------------------\nThanks for fixing email topics i can easily scan what topics i have while browsing on my phone\n----------------------------------------------------------------------\n\nThe topic can be found here:\nhttp://www.skylinesaustralia.com/forums/index.php?showtopic=169759&view=getnewpost\n\n\n\nIf you have configured in your control panel to receive immediate topic reply notifications, you may receive an\nemail for each reply made to this topic. Otherwise, only 1 email is sent per board visit for each subscribed topic. \nThis is to limit the amount of mail that is sent to your inbox.\n\nUnsubscribing:\n--------------\n\nYou can unsubscribe at any time by logging into your control panel and clicking on the "View Subscriptions" link.\n\nRegards,\n\nThe Skylines Australia team.\nhttp://www.skylinesaustr
alia.com/forums/index.php\n
yeah yeah I just got that too...
I was trying to remove some of the extra line breaks in the message... cept I replaced them with the wrong string.
Should be fixed now.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
