Talk to Sam about the idle problem. He would know better then anyone since he was working on the car and knows what was changed.
Looks promising though. When you are done see if Sam can lay your power curve over mine (Silver R32 with TD06 that made 240odd on his dyno) . I suspect your curve will be enough to convince me that the Plazmaman inlets are worth the money :P
Hope you get it sorted, be good to see another silver R32 makign some numbers in Vic ;)
I had a problem similar the your's with the missing so I went and bought the splitfire coil packs to but that didnt fix the problem had to the gap the plugs down to 7mm b4 it fixed it ,was a bit dissappointed with the splitfires really .I would stay with coppers to atm till you sort out your problems with the miss fire I use them all the time .Can U post up a pic of the engine bay with the plenum fitted please, thinking about getting one of them for my car but just want to know what has to be modified for it
Cheers Peter
The Splitfire are good in that you can at least be confident that the spark is even accross all the cylinders, and they are cheaper then new form Nissan. Mine are gappedat either .76 or .78mm. No issue even up to 1.5bar
On the same dyno....against an RB20 with GCG Hi-Flow R34 turbo.
Fix up the spark, also what are you doing for boost control. It seems to roll onto boost rather then really coming on and boogying. The other thing that may be worth trying is cam gears. A few ppl have now commented that could be the difference between good results and very surprising results. My first tuner said they didnt do anything on my car, the current tuner was obviously able to find power somewhere, could be the cam gears.
When Sam dyno'd my car i was running more boost then the engine was really tuned for. I asked my tuner to stop protecting me from myself and on his dyno im now making 26rwkws more so i would suggest cam gears could be something to look closely at. God knows 260/8.9mm cams didnt work in my engine :D
i had similar problems when i did my car the car turning off and not idleing is a tuning problem.
have him look at it again.
another thing i notice with your car you said it only pulled 117rwkw when it was stock.
mine pulled 142rwkw with just 3inch exhaust i dont think the exhaust would put that much power down??? would it?
has your mechanic checked the compression?
make sure you head gasket isnt screwed BEFORE you run 20 psi thorught it trust me i know from experiance. IT WILL GO BANG!
Looks promising though. When you are done see if Sam can lay your power curve over mine (Silver R32 with TD06 that made 240odd on his dyno) . I suspect your curve will be enough to convince me that the Plazmaman inlets are worth the money :(
Hope you get it sorted, be good to see another silver R32 makign some numbers in Vic :)
yea i have already booked in another tune with him next week. hopefully it rolls our of there purring like a kitten.. hehe.
ill let him know to do a tune Challenge between ur's and mine. then will have to line em up and let Faith know who wins :)
yea 117kw is a dead stock R32 gts-t no mods or boost. sam was telling me most stock R32's make 95-100kw's
and no i havnt checked the compression but it is a good idea. i will let sam know to check it 4 me.
ill try put sum shit NGK coppers in and gap em to 0.7mm see if that does anything.
cheers
will keep u guys posted
hey how you doin mate. look i know im a newbie and all 2 dis site but i had da same problem. wen u punch it n back off n hold the clutch in does it feel like its gona stall on u and come back 2 normal revs?? and da splattering??? ok i tried bigger fuel pump, coils, sparkplugs, etc etc etc. when i wen back dey narrowed it down 2 da vct. while dey have it on a dyno if it does it again get em 2 pull off da plug 4 it n play around wid da timing.
just a hint. it took me a month n every day at da work shop 2 get em 2 find it.
i have a r33 wid hybrid front mount single stage boost controller, bov, aftermarket fuelpump, platinum spark plugs ( which do make a better spark in my case ) that are gapped at .8.
even with da vct not connected i pulled 213.2 kw@tw. so im guessing u will blow way over wat u think :(
anyways good luck wid it n hope it works out well 4 ya :worship:
^^^ For those who don't understand jibberish:
dis = this
da = the
wen = when
dey = they
wid = with
And let me guess...you have an atmo bov...if you do then thats why you're having stalling issues...and you're making 213rwkw without a proper ecu? *cough cough*
Edited by limpus
With regards to the splitfires..
There's a thread over on the datalogit forum where some one checked out the coils with an FSA scope.
Long story short the dwll time within the pfc for the split fires was incorrect. Resulting in ignition breakdown at over 17psi odd ~290awkw.
Adjusted dwell time so that the coil is saturated and missfire disappears.
hahaha na seriously thats what i got on the dyno on a stock computer. like i said i havent had the car long so the previous owner must have done something 2 it. i know what u mean because i didnt believe it either when they told me.
not to take anything away from sam, but i really doubt that :D
i have not heard of a single healthy stock rb20 making near that figure, hell even CA's make around that at the rear wheels. ofcourse this depends on alot of things. even i and mates have have theirs dynod in stinking hot weather, one got 140rwkw and the other got 120rwkw, both absolutely bone stock, i got 150 with just a AM catback exhaust. all different dynos at different times BTW
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
