Hi guys, ive been looking at getting a r32 gtst. I was looking at spending no more than $10K. Will i be able to get a good, clean car for this price? I live in SA btw.
Also, many of my friends are vs commodore drivers and they keep telling me that an r32 gtst is much slower than a 6 cylinder commodore because the r32 has such a heavy body. Is this true? Are r32 turbos really that slow?
Finally, if i spent about $1000 on basic performance upgrades, what should i buy and what kind of performance gain would i see?
Thanks a lot. =)
https://www.sau.com.au/forums/topic/170114-buying-a-new-skyine/
well to start off with...r32 gtst's are not slow at all if anything a stock one with minor mods will prob be able to take on a 5ltr v8....being in SA and $10K for a r32 prob not at that price....if you want a nice and clean one you are most likely looking at $12-15K mark....and out of all skylines (r32, 33, 34) the r32 is the lightest....and if you can find a completely stock one...get a exhaust and front mount that way you can boost it up a bit...well good luck mate
Edited by Krishy
do you think a turbo back exhaust would give noticeable performance? do intercoolers give any extra performance or do they just allow for higher boost. cause i dont really wanna boost the turbo above stock. how about aftermarket bov's?
Turbo back will get you 15 - 20 rwkw. Intercoolers dont actually give etra performance, but do come in handy for more boost. I think the stock bov is good as it is....though one of the other guys was saying he wants to change his to an r33 bov.
you definately CAN get a decent r32 gtst for that much. specially when you're in SA...
probably can, but the main reason it will be forsale for that low, is because:
1) the buyer is too poor to keep it, or desperate to get the money for it - therefore probably didn't maintain it either, which may lead to potential headaches further on
2) it's already half stuffed, so by the time you put in a new motor it's not so cheap anymore.
Also when you factor in the insurance cost of around $1000 a year, petrol of about $50 a week, and everything else $8-9k is only the start. Anyhow, there are bargains out there, but there are also a lot of ongoing costs.
15-20rwkw seems like an awful lot. thats approx 15-20% of stock performance. do skylines have really restrictive exhausts or something?
15-20 extra kw would be more than noticeable when driving wouldnt it?
im going by my r33 figures here - stock for r33 is around 137rwkw - and now its at 164rwkw - thats with a turbo back exhaust and pod filter.
i do find that the exhaust made the car more responsive too....
wow, and they're less than $1000. I got a cat back for my dads 86 NA supra (i drive it), and that didnt give much of a performance boost at all. whats the difference between cat back and turbo back?
turbo back - is all the way from the turbo - the xforce system is only 900 or so from just jap....
I just bought a R32 gts-t for $8500, basically all it needs is a new diff coz one of the bearings is extremely loud, interior is perfect(apparently done 140,000kms) except one cut in passenger door, only a few minor dents in paint. The guys supplied me with RWC and a compression test, the compression was fairly low but I was expecting to spend $12500 for something like this so I have plenty for a new engine, also when on boost its starting to smell oily so I think I may need a new turbo(only $150). It even came with whiteline strut braces front and rear, 3" turbo back exhaust, and boost controller.
I was looking for a car for months though so don't except one to be available straight away.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
