There is a buyers guide Stickyed up the top I think.
My tip... look out for rust behind the door mirrors.
what is your petrol economy like how many l/100km i am going to be driving it every day to run a mobile service
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3143836
Use the SEARCH button. I have and this is what i've come across.
Driven carefully i.e. off boost most of the time with engine running well-
Around town 14-15l/100km
Highway 10-11l/100km
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3143853
haha and what should he do when he finds it? because its pretty definite he will.. :stupid:
Haven't seen a stagea without the TINY spot of rust behind the passenger mirror. Not a big deal at all - just something to be aware of. So saying I still haven't done anything about mine, after 1 year of owning it...
it shouldn't put you off buying one. Stageas are VERY reliable as you can tell by the lack of requests for help fixing problems on this forum. Most "help me" threads are self-inflicted in some way, and by that I mean that very few problems would relate to a stock stagea :laugh:
Edited by pixel8r
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3143944
I got mine removed and resprayed when the bodykit was done. I belioeve that would be the best way to do it. And sometimes that patch of rust can be bigger than you think, pull the mirror off and have a look first. Not in all cases but in some it can spread.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3145048
Defiantly get a compression and leak down test if you can, it'll show you how the actual motor is faring after 8-10yrs of use.
Basically same things as a skyline, if you can looks for shaft play in the turbo as well.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3145236
You can buy bottles of rust inhibator from hardware stores.
If you are after a quick fix for the rust problem, you could just brush this on under the mirror and inside the door. Then when it's dry, put a layer of paint over it.
Should stop the growth of the rust spot for a few years
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3145900
cheers, thanks for the info!
its been on my "todo" list since I got the car (um...about 14 months ago) - really need to get onto it...
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3146261
  • 2 years later...
I let mine go and the rust spot turned into bubbling paint about an inch under the mirrors. After purchasing, rust proofing and installing two doors my advice is don't wait. Do it now.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-5168995
check under the boot seal too,stageas love to rust there also a couple of guys have had trouble with rust under the roof racks. i hit mine pretty hard with a four inch grinder then rust converter until its all changed colour ,then paint it. Also the electric mirrors can be problematic once they get older but its just a case of pulling them apart and cleaning them up a bit.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-5169118
You can't fix the rust under the mirrors problem from the outside. There is a good tutorial on pulling off the door cards and pulling out the bit of foam that soaks up water and either replacing it with something water resistant or drying it out and waterproofing it.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-5170518
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
