What a great start to a Sunday morning.
Well, less than 5mins from my house, I was sitting at a set of traffic lights waiting patiently for them to turn green.... BANG..
wtf.
(photo taken a few km's up the road..)
How does one rear end someone on a quiet road, when there's no traffic around? HOW THE HELL DOES SUCH A THING HAPPEN!#%!!
From what I can tell the damage is as follows:
- both rear light brackets broken
- rear bar bent.. duh
- rear bar impact protection whatsit bent... duh
- bootlid bent down
and for the thing that really shits me
- drivers rear quater bent and folded slightly
I've notified my insurance company, do I ring the police too?
What the hell guys, seriously, just what the hell... *sigh*
https://www.sau.com.au/forums/topic/170253-rear-ended/
  • Replies 66
Yeah, we swapped details, I've even got a photo of his car... doesn't seem to be much damage at all on his. *sigh*
Well, he can't not accept responsibility.
T intersection... red light.
I was sitting there waiting at the red light, with one car infront of me.
*BANG*
I might let the police know just so there's a report of some sort.
I just feel so sick to the stomach when I think of how long the car will be waiting at the panel beaters for...
https://www.sau.com.au/forums/topic/170253-rear-ended/#findComment-3145134
why cant he take responsibility? he rear ended you while you were stopped....
There's no doubt about who's at fault. I don't think that will be an issue.
I wonder if the rear quater will be able to be fixed, or if it'll need replacement. There's a couple of noticeable folds under the petrol flap, and the bit near the tail-light is all flattened.
https://www.sau.com.au/forums/topic/170253-rear-ended/#findComment-3145149
Police told me I didnt need a report too when some idiot hit me for a minor acco.
Report it anyway over the phone and insist on a police report number. Call police assistance line 131444.
Insurance will sort it out but just in case the guy tries to avoid you at least its all reported
https://www.sau.com.au/forums/topic/170253-rear-ended/#findComment-3145151
The only reason the cops will take a report is if one or more of the cars had to be towed away.
In this case they didnt, so they didnt.
If the police did not attend the scene you will have to rely on the other driver taking responsibility.
Make a report of what happened. It will more than likely be required if the other driver tries to worm his way out of it.
https://www.sau.com.au/forums/topic/170253-rear-ended/#findComment-3145153
Thanks man. Called and got the number. The only details that they said they could take down though were time, date, and location.
https://www.sau.com.au/forums/topic/170253-rear-ended/#findComment-3145164
Hey bud glad you are OK.
I feel sorry for you but atleast the car can be fixed and by the pics dont look that bad.
With the police thing I would of gotten the Police officers name that you spoke too but it is no hassel because basically it comes down to your story and the other drivers. You have the damage on the rear end not him.
You will more then likely need to go too three different panel beaters to see who is the lowest then Shannons will say which one and in it goes.
Again so sorry and just glad you are ok
https://www.sau.com.au/forums/topic/170253-rear-ended/#findComment-3145201
hopefully things will be ok man....insurance should be able to take care of it - but you can suggest which panel beater to take the car to etc.
had somethign like this happen to me last year - luckily i wasnt driving the skyline....the guy was tailgating for a while, then at a left turn - i was waiting for the cars on my right to go through, and was inching forward. Then *crunch* - the f**king idiot rear ends my 82 civic. I pull over, he drives off. No damage, call the cops they said they cant do anything and that ideally the other driver should have stopped. he was an old man, but still didnt have the decency to pull over....maybe i scared him off cos I was wearing my beanie and my hoodie and gave him a glare....
https://www.sau.com.au/forums/topic/170253-rear-ended/#findComment-3145202
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
