hey guys,
Im trying to modify the wiring on the std boost solenoid in order to get full boost ... I read the DIY thread but it was a little unclear..
I was wondering if someone can explain it to me in other words.. I'm a little confused as to which end of black wire (ground) i should be grounding. and also it also talks about a lead wire to the black wire ???
I know I sound pretty hopless and i would appreciate any help ..
https://www.sau.com.au/forums/topic/170390-high-boost-with-stock-solenoid/
if your unsure, why not ground both ends? or leave it, run your own wire on a switch through to a ground... then you can choose what you want :O
best idea is to cut off the plastic around the wire (not easy to do) connect your own wire, run it into the cabin onto a switch, run the otherside to the chasis... thats what ive done, its wicked :)
but what you could do if your unsure about which one to ground, start the car and try grounding one end... you can hear a click if it works...
have you already cut it?
yes... but you need a switch on that too...
your basically making a T with the wires... when the switch is off, it will act as normal, when its on, it will be in high boost mode...
so connect your wire to the stripped wire, run your wire into the cabin to a switch somewhere, mount the switch, then run the wire off the switch onto anywhere on the chassis...
get it?
and make sure to clean up everything, dont leave any exposed wire anywhere...
to wherever you wish to mount it...
find a place thats out of sight but still easily reachable...
there are a few switch houses on the dash near the steering wheel that were never really used... use one of those...
i know a place where you can put 5 that no one else has thought of yet... but thats my thing :woot:
geez you're secretive Doof. :woot:
just-drift-it: stick your head under your dash there are brackets all over the joint. i mounted my switch on the right hand side in the coin holder. the closest bit available for me is a bracket for holding one of the relays under the dash. even had a convenient hole for me to bolt a washer crimp thing onto
where is the best place to run the wire into the cabin from the solenoid??
On the same side of the engine bay as the solenoid, but on the firewall, there is a rubber grommet thing that probably already has some wires running through it. If you run the wire through there it will come out in the passenger footwell. I found that a wire coat hanger helped pull the wire through.
with this grounding solenoid stuff, i just ripped it off completely n ran a line straight from cooler pipe to actuator, never had any dramas, that was 7lb all day everyday.
Cool so this works does it?? so you bypass the solenoid completely and run off the actuator. its better this way i guess so you dont burn out the solenoid but is it safe?? any opinions
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
