Selling my HR31 GTSX 2DOOR COUPE jap import skyline with genuine 120,000kms on clock, I am 2nd owner.
I will consider any seroius offers around $7/8k or possible swap for what have you.....
I have spent over 35k on this car and it is in immaculate condition nothing to spend just turn the key and drive plenty of rego, recently paid, all with receipts (the regretful sale is due to new house and kid).
ENGINE AND MODIFICATIONS
It has an RB20det serviced and tuned by Hyperdrive mechanics in Malaga, Perth
Garret T3/T4 hybrid turbo (rebuilt turbo $2000 in receipts)
Turbosmart 45mm external wastegate and 1" screamer pipe
Fuel system including "sard" injectors and aftermarket pre-pump in boot (have swirl pot if required)
Turbosmart BOV and in car turbo timer
Autometer boost pillar gauge
3" Mandrel bent exhaust from the turbo back with hi-flow mufflers and cat
$3000 worth of koni fully adjustable suspension & all new nolathane bushes throughout car (ride height and damper adjust)
17" Speedy rims and tyres
Larger R33 brakes sitting in my shed you can have
Polished stainless steel intercooler and piping
Aftermarket ECU Chip (lumpy-rom) tuned by Hyperdrive making 250bhp on 10 psi (can be boosted higher)
Aftermarket excedy clutch and larger billet steel flywheel (just installed 2mnths ago)
Laserline line alarm system with keyless entry
Alpine stereo system all new speakers in car and 15" sub and amplifier in the boot
Too many extras to list all...... Very neat and reliable car please email or pm me.... :P
Edited by davo79
https://www.sau.com.au/forums/topic/170473-for-sale-hr31gtsx-immaculate-spent/
  • 1 month later...
is that a silvertop with redtop covers or can lumpy do roms on redtops now?
No its a red top brother, lumpy's the man, If its nissan he can tune it.... Spent alot of coin on this thing at hyperdrive so If you have any mates that are keen on the car let them know. I think im selling it too cheap, I met this young fella just two months ago who imported one with no mod's and it cost him $9500... You probably know how much you can spend quickly when modifying a car and I have receipts for close to $30000
  • 3 weeks later...
  • 2 months later...
Man, i'm freaking amazed at how cheap people are selling thier HR's for these days, i've thought about selling mine but if thats the type of price i'll get i'd rather keep it. or if i do sell it i'd consider advertising it over in japan and send the fckin thing back there, probably get more for it that way..
Good luck with the sale dude.
just stop dropping the price, your breaking my heart! :laughing-smiley-014:
:rant: Tell me about it mate it's way too cheap I would love to keep it and keep modifying :( but what can you do
I have to sell the mrs is busting my balls to sell and get a 4door family car :glare:.....maybe i'll get a stagea wagon? (big boost):kiss:
Just put new front tyres on the car....will advertise it in carsguide.com this week
:yes: I can't believe no one has snapped up this beauty. I'm looking for one in the Sydney area and can't find one as good as this for the price. I should hop on a plane with my cheque book and drive the bugger home!!! What an awesome trip in such a great car. :huh:
New seat covers and battery installed this week just make a serious offer and I will give you a call...went to trade car in and they only offered me $4500- $5000 So I would rather let a fellow enthusiast buy it before the car yard c'mon guys great car going really cheap it's making me upset........ :D
Someone selling a bunky one for $4500 in canberra so i dont think $7000 is unreasonable
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
