Fuel of choice??
104 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I use anything that is 98 that has a 4c voucher lol mostly caltex, then coles, if i have no voucher or if i need fuel asap i just get whatever is not heaps crowded (i wont hang out a driveway blocking traffic just to get 2c saving) or is closer. i dont think that having any of these fuels is better or worse, i think having a different/old oil/filter or dirty air filter etc would be more detremental or beneficial than fuels. i haven't tried the V Power Racing though, havent seen it in Newcastle before, only the other one at Shell.
Good thread but got everyone talking haha
Peace :(
Ultimate, V-Power and synergy 8000 are the only petrols I use. I am pretty sure synergy 8000 is the one i get the most k's and performance from but who knows, they are all good. But V-power racing contains ethanol I am almost sure so I did not want to use/try it. Plus it costs the earth!
Highest octane I have ever seen at a pump in the US is 94. I use 93 octane Mobile. I've tried a couple other brands, but Mobile stations are all over the place here and my car seems to run well on it.
i use ultimate because i am in qld, so it is actually ultimate. and i had a mate do an octane rating test on some and it was about 98.3 ron (where he worked a rep for a fuel additive company had an octane rating tester). he also discovered that adding 2 bottles of nulon pro strength octane booster will lower your octane, but adding the correct amount will raise it.
i don't use shell where i live because they had problems with their tanks rusting and it gummed up a heap of fuel.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
