  • Replies 40
  • 5 weeks later...
  • 3 months later...
Hey guys.
I will make one for the R32 GTR and GTS-T but they consume enormous amounts of my time and countless lunch hours driving around dropping stuff off, picking stuff off and going to the bloody post office.
I've just come back from honeymoon and have got a busty few months coming up, but when I have some spare time on weekends I will give it a go.
If anybody has a guide already fitted to a car (Greddy/ARC etc) who could lend it to me, it would make my life considerably easier (and would score you a free one :P )
BASS OUT
  • 1 month later...
  • 5 months later...
Well, I design them and sub-contract the manufacture.
Pics below.
Laser Cut, CNC Press Braked and Powder Coated.
R33 GTS-T Series I, Series II
R34 GTT standard bar and Nismo Bar
Stagea Series I with and without Scoop
Stagra Seres II with and without Scoop.
:thumbsup:
Wow.... What awesome FABRICATION skills you have demonstrated tp everyone here. Care to explain how you design them so the people demanding an R32 one might actually be able to have a go themselves???
This is ADVERTISING!!!!
Move the thread.
Move the thread.
This has come up many times on the forums now and thread will be staying.
It doesn't violate any forum rules and its in the best interests of the forum users, he provides a quality product at a competitive price. If you think you can do better than please feel free to post up to let us all know :blink:
Cheers Ben
Nuclear Skyline.
It's fabrication. Please explain how spending many many hours designing, drafting and then prototyping, cutting, and punching is not fabrication?
So I use technology for my fabrication.... So do the vast majority of fabricators who make more than one of something.
Not critising the quality or the actual design of the product... Probably is a fantastic product.... I thought though:
Welcome to SAU's newest forum, the Fabrication section.
This is the place to discuss custom fabrication of anything car related, like;
tools used - welders/band saws/lathes etc etc
methods of fabrication - metal Fab/Welding/fibreglassing
problems encountered during Fabrication (help)
Custom car fabrication/roll cages/rust repair
tips on welding methods
fabricating custom IC piping and ways and techniques
fabricating IC mounts/ oil cooler mounts
surge tank boxes
out of the square conversions
build your own strut braces
Just doesnt seem to fit
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
