Vertical Flush Mounting Amps In Boot
QRI05E
 Share
Hey guys, as we all know that skylines and other coupes have minimal boot space and was just wanting to construct a vertical flush mount rack for my amps. Im wanting to make them on the side compartments of the boot so that i can maximize the boot space.
Has anyone done this? I have a basic concept of constructing a vertical flush mount for an amplifier however would like some experianced insight, tips, tutorials and pics if possible. Here is a pic just you guys have a rough idea.
Any info would be appreciated!
Regards,
Sarkis
Well im sure all those $$$ custom audio installs dont have any issues with rust. Just wanting some ideas in terms of design and construction.
Cheers
hehehe I have checked out almost every car audio site possible and cant get any tute's or pics.
Yea i was considering using card board to make a template then construct it using 16 - 18mm MDF. I could use L brackets & pop-rivets to support it. On my next day off ill strip the boot interior and see what i have to work with. Ill try and post up some pics.
Cheers
Custom boot installations done by a real professional have no SCREW HOLES in any part of the metal of the car.
But not everyone is going to expose their trade secrets on how to do it properly. Backyarders who dont understand why professionals charge money for boot installs have devised the PANEL AND SCREW idea and then they boast about how they did the same job for next to nuthing.
I can do a boot install in any car with no damage to any metal part.
If u dont mind rust then do the usual bracket and screw idea it works for a lot of DIY guys.
Edited by Adelaideprosound
I appreciate you advice Adelaideprosound, I have no means of drilling into the metal of the car but rather secure it on the the plastic and rubber mouldings. I personaly dont have the cash to pay an Audio workshop to do such an install and thats why i want to give it a go myself.
Any other advice would be greatly appreciated!
Cheers
Another thought, amp rack style setup which is bolted to a flat piece of MDF that has been affixed to the floor?
Just looked back through some old posts, Kezza had something similar altho not in the same location:
//edit: I see George has done some fantastic ones too from the pics on his website :(
It will add weight but heres and idea..
A full length mdf peice id say maybe 10mm thick .. cut it to the shape of your removable carpet..
Then make a box for the amp and screw that box into the side of the fake floor .. carpet it all and restain it via the two metal peices which prevent the spare tyre accidently flying out just infront of the fuel tank they are like reinforcement struts .. you dont need to worry you can screw into them :( ive done it
 Share
    • Go to SP mufflers and get the muffler of size you want and make a nice mid muffler. It's about that simple! I have 2x 3.5 Magnaflow straight through Mufflers and while it's pretty loud with the Varex open, it's quiet enough with the Varex closed. You can also buy off the shelf Magnaflow straight through mufflers as well. You also have a turbo to quiet the car down too. Don't overthink it. Buy my extra Magnaflow muffler sitting on a shelf doing nothing (buy it new, ignore this part)
    • Centre-offset muffler under the floor, same as stock. Just....3.5". The change from straight pipe there to centre-offset will mean that you need to remake some of the pipe (add a bend or two).
    • Hey guys. So my R34 GTT has a custom 3.5” exhaust (done by previous owner) with a high flowing cat, and then just a Varex cannon muffler on the back. The car does drone alot and is really loud even on highway driving just cruising, as you can imagine due to the Varex muffler basically being a straight through with the valve open. As much as i love a loud RB, it can be a bit much with no other muffling in line and just driving casually. I wanted to lower the volume output on the exhaust a bit, as well as remove the drone (probably a way to do both at once), and was going to do it all myself as I am a fabricator and have done exhaust work in the past, so the fab work isnt my issue, im just not sure on the right product or type of product to use to get the job done, and i doubt an exhaust shop would be wanting to help me as they wont be making any money from helping me, unless they supplied the product? Anyway any help or guidance in best way to approach this would be awesome   Thanks in advance
    • Meh, whilst the Honda is a "really" good car and has potential if you want to drop coin on, it was uninspiring for me to look at, but, it did serve its purpose and is now in the boys hands, his happy, his girl is happy, as she wasn't to keen on the noisy old Patrol, and most importantly, the Minister for War and Finances is extremely happy that her "little baby boy" (6'2 nugget who is currently training to be a copper, which will make 3 coppers in the immediate "circle of trust") has a well sorted reliable car that doesn't guzzle diesel Me, I'm more than happy with the NC MX5 that I replaced it with, it's a fun little car that I like looking at, like driving, and yes..... I do like the fact that the maintenance and modifications that I have done/will do are plentiful and relatively cheap, well........ while staying naturally aspirated slow that is, and that's all I really need for a fun little daily, I can rev the 5hit out of it rowing through the gears and never really break the speed limit  In saying that wicked word, "modifications", I've already ordered something for some noise and an additional "3 ish" horse powers, or whatever it gives, in the form of a header, and, a new set of "cheapo" BC coilovers that are already sitting in the shed waiting to get put in, I had the same BC's in my old NB and found they were fine for the street, hwy, and the occasional track days I did in it, they have 6kg front and 4kg rear springs which is about 10% stiffer than the stock springs which I found worked well for their price  I've also already been in touch with MX5 Mania in Dural, so once the header is on it will get a ECUTek RaceROM tune there (I cannot rev match for 5hit, and I loved the RaceROM rev match and FFS in my old 86 "RIP") In other, maintenance news, I put some new sparkler plugs in it, and have a new set of DBA Street series pads to put in over the next day or so, I'm running the DBA street series in the SS and Honda and really like them, they work great and are not dusty at all I've also booked in a few days leave over this weekend to give me 4 days weekend do some paint correction and give the leather seats some conditioning and interior some Bissell and steam cleaning OCD lovin', the carpet and interior looks clean, but from my experience with the Bissell IRT carpet, and the steam cleaner IRT trim, looks can be deceiving I've also found that finding a detachable hard top is proving problematic, the main reason why I didn't like the NC initially was the power retractable hard top that I seen them with gave the roof line a weird look, the detachable roof though looks good, and is a same shape as a NA/NB hard top, similar, but unfortunately not the same as it has different fixture point on the front, so fitting a easy to get NA/NB detachable hard top is no bueno New Old cars are fun, cleaning, hunting and playing around brings much joy How are your beasties going? Do you still have the Skyline with the LS???, or Barra??? that you were playing with
