Just had a new alarm installed in my r33 yesterday, but the battery went dead overnight. I gave it a charge, and checked the current coming out of the battery with no interior lights on - 400mA. Seems like quite a lot. I thought maybe the alarm might have a backup battery which would be charging, but it should have been done by now if it was.
I tried pulling fuses in the engine bay - no difference. The only fuse in the boot which made a noticeable difference was the main fuse, which doesn't tell me much (even then, something was still drawing 100mA).
Are there other fuses in the car I can check? I thought of removing power from the alarm but it's in a really tight spot and all black wiring etc.
What to do?
Thanks!
talk to your installer...
its that simple... alarms are something left to proffesionals, especially on such nice cars... and its his work too, you should never let one sparky touch another sparkies work...
so you have a current probe? pull fuses until it dies. this includes the alarm fuses.
400mA is enough to flatten a battery over night.
failing that - take it to the fitter and let them sort it out..
I'd be taking it STRAIGHT back, its only 1 day old! Installer needs to fix the problem.
I'm just gonna see how long it takes the battery to run dead again. I had the car for 6 days and it always started easily, and that included 2 days of not driving it. So if it dies in less than a few days, I'll know the problem was caused by the install, and I'll ask him to come back.
Turns out it wasn't the installers fault at all, just a huge coincidence that the battery lasted a week no problems then died the day of the install.
I pulled the stock headunit out and that dropped most of the leakage (thanks Chris). Still 150mA elsewhere though (100mA on 'TAIL L' fuse and 50mA dunno).
If anyone has any suggestions on what to look for on TAIL L I'm all ears!
Cheers!
Edited by bombastic
Props to Leon for a fine job after all :D He spent half an hour on the phone to me today discussing it, and was going to come out tomorrow and sort it out for me until I discovered the fault.
I won't plug the name of the business in this thread though as I would hate for anyone to be put off by the title of the thread if they did a search. But if they have read this far then no harm done.
Apologies if I gave you any grief, Leon! The main reason I came on here and posted was I wanted to be as sure as I could that it wasn't your fault before I got you out. SAU wins again, credit goes to Chris for suggesting stereo.
stereo is a common one. clarion and pioneer of that vintage use the same amplifier (usually a toshiba item.) and it develops a short. worst one I saw was 1.25A. that fried a battery over night before we found it . (this was an alpine unit)
spoke to him for 15 min myself before he rang you clarifiying your problem. get a base draw on the car (should be 50mA or less) and work out where the rest of it is. 150 Ma will drain a battery but NOTHING like a 400mA one will. if you drive the car daily it wont be a probelm. problems ring us first :D
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
