Hey,
Im searching for an oil leak coming from the turbo side of the motor, its leaking quite a bit and i want to fix it ASAP. So now comes the hard part. I need to remove the top parts of the turbo assembly to take a look at the return and feed lines. I dont want to get to much into the removing, kinda scared to get stuck somewhere. Anyone have any tips? Pics? or How to?...
I figured that fellow rb26`ers would like a how to for removing the turbos, anyone? :cool:
Thanks Guys
Wil
https://www.sau.com.au/forums/topic/171434-r32-gt-r-turbo-assembly-removal/
I will be doing this soon too... where can you order the workshop manuals? (Stupid question probably)
I got mine from importdriver.com.au; it cost $500. An electronic copy may probably be obtained for less...
The workshop manual is pretty useless for this particular job, though :domokun:
Regards,
Saliya
Be careful what you get yourself into. just having a look at the lines etc is ok, if you just want to change the washers if they're leaking from there. But if you're going to do the gtr turbos, it's a massive job (my friend's car still isn't finished) compared to doing a turbo on a gtst.
and usually, if your going to remove some bits of the turbos, and they are standard.. perhaps its worth replacing them with something better?
and while your there do dumps, and then this list seems to go on and on and on.
enjoy!
Hey guys, thanks for the tips.
Now I think i know where the leak is coming from. its coming from the banjo nut oil feed line going to the first turbo (turbo closes to the front of the car). Im in the process of takin off the exhaust manifold, but i dont know if that nut is reachable from the top or the bottom of the motor. Anyone know?
Thanks in advance
Ive replaced twin turbos on my rb26 before. And ive had to go back and fix coolant a leak a few months later. Theres no easy way. If you are trying to remove the rear manifold/turbo, you will have a prick of a time removing it, unless you remove the front turbo first. I dont think you will get the rear dump pipe off, with out removing the rear turbo completely either. Perhaps try removing the powersteering pump And dropping the ac bracket and lowering it out of the way. Might get access that way... and also be able to better inspect the return drain lines while you are at it . Have fun.
Oh just re-read your post and you said the front turbo. Much easier.
Thanks Spilmer.
Now do I need to take off the front dump pipe off the first turbo before i can get the exhaust manifold off? in the manual it says lower turbocharger before taking manifold off. But i cant see how the turbo will move downwards if its attached to the dump pipe....
Anyone can enlight me on this? :)
Thanks again,
Wil
Thanks Spilmer.
Thanks again,
Wil
Hey,
You need to disconnect the dump from the exhaust; you might
find it easier to remove the entire front section of the exhaust
from both dumps to the cat because then you have plenty of
room to move.
Then undo/slide/undo/slide/undo/slide the turbo/dump assembly
down off the manifold, then you can remove the manifold.
Regards,
Saliya
Just a quick question....How the hell do you get to the dump pipe bolts? Do I need to take somthing off to get there. It seems impossible, tried a couple times but I cant seem to figure it out...
Also the oil return line for the first turbo is hard to get at, any tips?
Thanks for the info guys.
Wil
Wil
From the bottom of the car, use a socket + extension and undo the bolts on the
dump <-> exhaust flanges (NOT the dump <->turbo flanges, they are inconvenient
to undo while turbo + dump still on the car).
Like I said before, you might find it easier to entirely remove the front exhaust section
before trying to remove turbos.
Regards,
Saliya
Alright! Good info guys.
One more question if I May :P....The oil feed line going to the first turbo, is it reachable from the bottom without takin the turbo off? or do i need to to remove the turbo before I can reach it?....The reason I ask is that im pretty sure my oil leak is coming from the oil feed line and I just want to check the washers if there in good condition..
Thanks again, you guys are life savers, just like pain killers :thumbsup:
Wil
Wil
Yes, you can undo the oil line(s) without removing the turbocharger (the
recommended procedure from Mr Nissan is to do it prior to turbo removal).
This is the oil line on the turbo itself; don't remember if you can easily get to the
eyebolt/splitter on the block with the twins in place nor if you can do it without
removing some air pipework and/or heatshielding.
The easiest way to find out is to stick a hand and a spanner in there...
you might find that a set of stubby ratchets makes things much easier (I did).
I should mention that the easiest way to find out where your oil leak is coming
from is probably to clean everything up with degreaser, start it, and then have a look.
If you can get to the eyebolts with a spanner you should be able to get
to them with your eyes (or eyes + mirror-on-a-stick) first - and looking's
much easier than undoing, replacing, and redoing...
Regards,
Saliya
Cheers Mate, Thanks for the good info.
Im currently getting some new copper washers for the splitter eyebolt and the eyebolt for the feed line on the first turbo. I will be replacing both of them after inspecting the ones that were in at first, they are crocked and squished. Im pretty sure that i covered where my leak was. Im gonna anneal the washers, replace them, clean everything up while im under there and then i can see if it still leak. I have another question, can someone explain to me how the turbos gets there oil?...I dont understand where the oil is coming from, I know theres a line thats goes across the 2 turbos(where the splitter/eyebolt is) and that line goes in both turbos, comes out the oil return lines but I dont know if im missing something I cant seem to figure out where is the oil coming from?...
Thanks again for all the info, ive couldnt done it without you guys. Remind me to bring you guys a case of Alpine (Acadian beer) if im ever going to australia.
Wil
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
