Had a good time watching all the cars ... was wondering what some peoples results were ... the best i can remember was most skylines getting 13's ... martin soarer doing low 13's ... an old school skyline doing 15's (about 45 times too i might add :P ) ... and excel in the low 13's ( i wonder whats under the bonnet??) ... that red rotary drag car doing a 9 something and made me deaf ... keirs 32gtr with a 10.42? also made me deaf ... lots of commies in the 13's 14's ... falcon with a 12.9?? oh yeah ... evos with low 13's and 180's in high 12's??
correct me if im wrong ..
https://www.sau.com.au/forums/topic/17154-drag-results/
Very nice times there man! It certainly looked the goods.
The whole car was twisting and rocking at the 1st/2nd gearchanges - I was sure something was bound to snap with all that force/grunt! What mods do you have? Did you import the car yourself or is it local realease? (not sure if they sold them here or not).
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355002
my friend with me has an evo4 ... he didn't race it and it was parked outside with next to my car ... it used to be 224kw@all 4 ... that was with a hks turbo ... and motec computer tuned by rpm ... he never races his car though ... hes since taken out the big turbo and made everything stock agian ... lookin to sell this evo4
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355087
Good to see everyone out and finally put some faces to names.
I did 13 passes and my clutch didn't even stink on the way home!! Even though the commentator (Andrew I think) thought I was trying to fry it, with so many runs in a row.
The track was bloody slippery at first but good to see some nice rubber laid down throughout the day. I finally broke into the 12.4's running 15PSI with a 12.421 at 110.26MPH (60' 1.835sec).
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355619
Great day, thanks Ivan & crew from RPM. First time I've ever done it and was good to drive home OK (apart from a now leaking exhaust manifold that I'm told is no big deal for a while!).
13.42 ET, 106.5mph, best 60' was 2.11s.
Main thing is that I beat grepin, Chris32 and Bugalugs :burnout: Dare I say quickest GTS-T on the day! Bugalugs' run were amazing though, 13.44 I think and 106.99mph!! And that's with a stock ECU...good stuff.
grepin, do you now surender? Do we declare WW1 has been won by Freebaggin .... or should we wait until after the climactic battle this Sat at Tilbrooks for the outcome of WW1?
Then WW2 starts soon after!
https://www.sau.com.au/forums/topic/17154-drag-results/#findComment-355737
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
