Clint32,
Shit, I saw your reply and thought doh myself, as I forgot about your runs. I assumed the E/Ts were better than mine due to the very quick top end. Get your launch OK and it'll be a 12s job for sure. Chris32 had trouble getting a good start/rpm balance too.
Thank u Ivan/RPM Performance for a great day.
It was my first time down the 1/4 so it was nice to do it without a big crowd.Part of the reason why i wanted to do this was to backup my dyno results from the dyno day at Tilbrooks and prove that it was no fluke.
My best was [email protected] 60` and as Freebags said i did do a 106.99mph 13.5.
It was good to catch up with you guys again and when i'm settled into my new house i should be able to get out crusin again.
Freebaggin-I'm not sure how long that gasket is going to last being that you are missing 2 studs.You may have to order that T88 earlier than you thought so they can fit and fix all at once to cut cost.
Grepin-I`m still baffled by your low mph.I spose just let WW2 begin and kick F/B`s ass then.
Matt
Yep, it was a top day, big thanks to RPM
I had a few good runs, but I really struggled to get it off the line. My best run of the day was 14.03 @ 104.9mph with a 2.5 sec 60ft
Don't reckon the hard track style suspension and cheap Falken's helped much, maybe next time I will get some decent rubber and try and knock 1/2 a second of my 60ft times.
At least after 8 runs nothing broke
Chris
Thank u Ivan/RPM Performance. Specially borrow me the tyre pressure gauge :rolleyes:
never been to drag race b4, i was VERY excited. have 2 15sec pass with 32 psi tyre ,then i borrow ivan's gauge and release the tyre pressure to 22psi and done a 14.5.
being the slowest skyline (tubro) of the day,[email protected] with a 2.299 60'.With same mod of other member(exhaust, intercooler, boost controler) I found that even i have a OKAY lanuch, my car start get slow down at 2 or 3 gear, (seems the boost pressure can't keep at what i set) i try to adjust from 12psi to 13.5psi and guess what, i did worse time in 13.5 psi - [email protected]
i have order a e-manage from japan this morning after doing some disappoint time. With better tyre, hopefully i can break into 13.5 at the next meeting.
after 9 runs, my heavy duty clutch is not heavy duty anymore :)
Originally posted by hippy
agree with u skyppy .. i saw alot of ur runs tin .. u also got not so good launches .. that greddy emanage would cost something like 1k?? spend it on ur suspension .. lighten flywheel ... tyres ... its all power and torque ... not that i know anything about drag racing .. :rolleyes:
i already got tein HR suspension on my car
i was quite interest at lighten flywheel, but someone told me they will affect the drive quality. Actually anyone who have it, can u told me what is good or bad after having it? but anyway, it won't be purchase until i blow my clutch
tyre was a definate, they are quite worn, i am still waiting my aftermarket rim arrive from oversea, so tyre will be purchase when the rims land.
from the MPH i run, even i got better tyre, i might be just able to break into 13sec, as my aim is low 13 or even high 12, i need more power(more boost). When i get the e-manage, i can have more power and even running higher boost, i can buy them for around $700, and i already have a e-01 to match, rather than a pfc for doulbe the price, it seems not a bad idea...
Lightened flywheel's only really improve your acceleration from lower in the rev range. When at the drags you are always operating at the top end of the rev's i.e 5500-7000rpm so apparently the lightened flywheel is not benificial.
I have a chrome molly lightened flywheel and noticed at the lights it was easier to take off, gears rev match heaps quicker. For the street lightened flywheels are quite good. No loss of drivability or fuel consumption.
the best things to improve the time instead of spending more on the car, is improving my launching skills and shifting skill.
i think i shift alright... :D
Maybe a bit of weight deduction on my car, but more important, is LOSTING weight myself!! :D
i was 75kg when i come to Aus. 3 years ago, and i am near 100kg now, if i can lost some weight to i used to(75kg), the car is 25kg lighter,plus take the audio (2xkg) and spare tyre (10kg?)out, definatelly can be 1/2 sec faster!!!;)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
