Stops your engine moving around.
Increases horsepower and torque...
You will see it most effictive in an SR engine tho.. They move around a fair bit..
Esp if you got cams etc etc.. for 80 bucks from justjap.. probably a nice little upgrade
You might as well get the brake fluid stopper thingy..
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3162589
i think hes talking about a master cylinder stopper,
its basically a bracket that mounts to your strut tower with a plate or bolt that press up against your brake master to stop it flexing against the firewall when you hit that anchors.
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3162610
Edit: ^^ yea what he said..
so stops your brake fluid from moving around all the time when you brake hard or go fast around a corner
^ brake fluid right? hmm yea think thats what it does..
Edited by siddr20
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3162614
I havnt noticed any in my friends worked up s15.. thats got cams etc in it..
If you got adjustable castor rods like me, then you can feel those thru the cabin lol..
not to sure about engine dampers..
Edit: pm PLYNX.. hes got one in his 33.. ask him if he feels anything!!
Edited by siddr20
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3162624
I'd hope they save engine mounts.
I've done in one set of new engine mounts. :D
A mate in his GTS4 also did a set of engine mounts.
The Skylines appear to be fairly well setup; even with a busted engine mount they don't move around that much. Previous v8 aussy cars I've owned have the whole shifter moving often cracking your left knee. :S
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3163203
I put in a HPI engine damper in my car and had it on for 3 years+....... i reckon it was a waste of money IMO. haha
i do circuit/drags quite a few times a year and with 135,000kms on the body. engine mounts still seem fine..(ithink)
if i had the choose again i rather put that money elsewhere but i dunno .
As for vibration in cabin.. feels the same to me.....
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3163247
they hardly do shite on RB's as the attachment point is a flexible bracket (factory lifting pont).
this is all you need to know.
everytime I've tried to buy one in japan my (knowledgeble) friends there have talked me out of it. When I asked if they were good his exact words were: "looks part only". meaning it's just useless bling. if you like the look by all means get one. if you want a stiffer mount for your engine just use the nismo engine and box mounts.
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3163270
lols. a brake master stopper doesn't stop brake fluid moving around. it stops your firewall flexing when you are hard on the brake pedal.
https://www.sau.com.au/forums/topic/171563-engine-damper/#findComment-3163456
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
