Insurance costs
Are RAC insuring Skyline turbos again?
They decided not to and when I enquired with their management they said it was due to the difficulty of getting parts.
I put them onto my contact at Northside Nissan to prove there was no problem.Must've convinced them
My 34 costs $1050 through Shannons but then I'm an old bastard with max NCB
Cheers
https://www.sau.com.au/forums/topic/1716-insurance-costs/#findComment-32665
Yeh i thought the same:confused:
I tried rac and they told me to go jump due to the fact i have a 91TT supra and i am only 21.
I ended up going for a broker called harrintons: 9388 1299 and they did mine through SGIO for 2400 but unfortunately icant pay it in increments has to be all up front cause of the broker.
https://www.sau.com.au/forums/topic/1716-insurance-costs/#findComment-32684
Hey Guys,
I am with the RAC .... I am paying just over $1200 a year to insure my 95 GTST... Oh yeah and I am 23.
I am pretty happy with it considering SGIO was charging me $1200 a year to insure my VL Commodore.... Which is for sale if anyone is curious :uh-huh:
Now that I got my shameless plug out the way.... Back to browsing the forums.... Hey at least Ianswered the thread question :D
MrGTST
https://www.sau.com.au/forums/topic/1716-insurance-costs/#findComment-32777
Its all about the number of turbos, if you say TT then you get screwed. This is what happened when i was looking at cars, and RAC wont even insure my dad for a Z, he had to go shannons.
They think more turbos = more power which i spose is usually the case, but if you said i have a 800cc suzuki mighty boy twin turbo they still would knock you back...
Wouldnt that be an interesting car...
https://www.sau.com.au/forums/topic/1716-insurance-costs/#findComment-32961
Oh yeah!!! that would be a little crazy :lol:
Dont shannons say u can only do like 10k a year or somefin?
https://www.sau.com.au/forums/topic/1716-insurance-costs/#findComment-32980
Heya Guys,
Yeah I am one of those RAC groupies aswell! I am 23 (as of two weeks ago) insured my 95 GTST for $24,000 and am paying $1400. I did enquire with RAC the 300ZX twin turbo (what was i thinking! ahah) and they said they wouldn't insure me due to twin turbo's and i would have to wait till i turned 25! so looks i am going to have to tell my dealer in Japan not to ship over my brand new R34 GTR for a couple of years!...... AHAHAAHAHA!!! YEAH RIGHT!! I WISH!
as R34 said Shannons are a good import enthusiast company for turbo lovers such as us, you do pay a bit more but i would rather pay a bit more for that extra piece of mind! i have heard they will insure nearly all cars...at a price...
P.S my friend smashed his black 300ZX just out of northbridge under the tunnel (near omni) and he had NO insurance!
https://www.sau.com.au/forums/topic/1716-insurance-costs/#findComment-33091
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
