Hi
My R32 when started cold stalls straight away if you dont rev it as soon as you start it.
What can cause this issue? thought it was a dodgy cheap ass battery but I swapped it with a good working one and same issue.
Please advice
Thanks
https://www.sau.com.au/forums/topic/171710-starting-issue-stalls/
mine has been doing that lately, but thats cause it has been sitting in the cold, not being driven...
i think its just everything is cold... theres a slight chance it could be a lack of power, but i doubt it...
does it only do it when its cold? cause my 33 stalled last night, and its being worked on, so it hasn't been run for a little while... it wouldn't idle properly... not at first...
other then that, its never had a problem before...
The car starts but for like 3 secs cos its idling very very low then stalls
if I start it and blip or rev the throttle a little bit it idles like normal (cold start higher rev) and runs fine, starts straight away when warm
I've read that if its the air regulator it'll idle high as well when warm, so this cant be my issue then...
AAC valve is when you have crap idle but my car idles fine.
Can someone please share some ideas
Could be the AAC not going to 100% on startup for cold start idle and staying at the 30% ????
Or is it the other way round???? Damn financial year end messing my brain up :closedeyes: Meh either way.... definitely check the AAC valve... I had this problem... car idled fine just took a couple of goes to keep it running in the morning!
*edit* we also found that the ignition switch was worn - if it takes a while to crank over too, check the voltage on it. I originally thought my issue was fuel on cold start (aftermarket ecu) ended up being 2 problems - ignition switch dropping current resulting in excessive cranking before firing and then the AAC being dodgy and not opening all the way for cold start and causing the stalling issue after a second or two.
Under the throttle body (guessing RB20DET), is a "cold start air valve". Can't recall if it's supposed to be open or closed at (cold) start, but then a bi-metallic strip cause it to close or open.
Pull it off, peer down the barrel. Tell us what you observe.
Yeah mine has starting problems also on cold mornings;
Here is a video;
Similar to your starts?
Just blip the throttle when car starts, thats what i do
edit;
this might help also
http://www.skylinesaustralia.com/forums/in...=162728&hl=
cranks fine
Rekin very similar but mine goes to normal cold start idle like 1500rpm, your's a bit low...
Yes just blip the throttle and everythings fine.
But I still want to sort it out as it shouldnt be like that.
what does the cold start air valve looks like? is it like the air regulator?
It's the only thing under the throttle body. Hoses attached to both ends. You can't miss it (unless you're blind!).
Actually, starting to sound a bit like dirty injectors. Had them cleaned recently?
Hey guys, i have the same problem and even better i know how to fix it!
my engine temp sensor is kaput, it is giving a higher resistents level then it should have been which indicates to the ECU that the engine is hotter then its actually is. the result is the wrong mixture of actions and fuels during startup which results in the stall.
i havn't had a chance to get myself a new sensor since uni is kicking my ass but i'm confident this will fix the issue.
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
