Hi,
I have just pulled the gearbox out of my r33 gts-t so i can install a new clutch however i cant get the bolts undone on the fly wheel so i can go get it machined, has anyone got any tips?
The car is in the garage up on car ramps so i dont have a whole heap of room to move a crack bar...
I have tried using an impact driver but still no luck..
On all my previous cars i have been able to get the flywheel off, but this one just wont budge...
If anyone can help it would be great.
Thanks,
Scotty.
https://www.sau.com.au/forums/topic/171873-flywheel-removal/
no trick to it mate, they are just tight. If you dont have a ring gear stopper just put a bolt back in and use a pry bar in the flyhweel teeth to hold it, then biggest breaker bar you can find.
can you get the car up any higher?
Some people recommend that you hit the flywheel bolts with a hammer, then try the breaker bar again. I used the approach on the three stuck bolts on my car and it worked, but i'm still not sure its a good idea...
Tapping the bolts with a hammer is a good move on anything, wont damage anything. One firm 'tap' can ungrip any threads that have started to bond which would otherwise make it extremely hard to get loose with just a breaker bar.
Edited by deant1
Thanks for your help guys,
Since the rain has finaly stoped i have been able to get back to working on the car.
I did get the flywheel off, i ended up giving the bolts a good "tap" with a hammer and used a longer breaker bar.
Although i will be replacing the bolts as 3 of them have started to twist at the head.
Thanks,
Scotty
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
