Hi drift_me_silly, you asked "q....if r33 auto diff fitted to r32 with r 25 box....would fifth at 100k's drop down to around 2ooorpm?..."
As far as I know the Auto R33 diff and the Manual R32 diff are the same ratio (4.363 to 1). So I don't understand the question...
The Series 1 R33 clutch (push type) is the same as the R32 clutch. The Series 11 R33 and R34 is different (pull type). We have used the same OS Giken twin plate in an R32 GTR, R32 GTST and S1 R33 GTST. Fits straight in. Hope that answered your question.
The Trust 6 speed has a close ratio set of gears whereas the R34 GTT has a wider ratio set. So not comparing apples with apples. Any car with any engine would be faster accelerating with the close ratio gearset than the wider ratio.
Hope that helps
  • Replies 44
My R32 GTSt has a flywheel and clutch meant for an R32 GTR, so whatever the differences, they don't stop you fitting/switching.
... and as for fitting an Rb25 behind an RB20, im not having any trouble with my box at them moment. (im guessing i have between 135-150rwkws) At what sort of rear wheel power figures do they start having troubles. And what troubles surface first?
Hi guys, the starter motor bolts up in the same spot, so the flywheels must be the same diameter. The bolt pattern on the crankshafts are the same. All the gearboxes have the same size and splined input shaft. So if you consider the package (flywheel, pressure and clutch plate), then all Skylines with the push type actuation are interchangeable.
RB20 flywheels are a bit lighter than RB25's and the clutch friction surface is smaller in diameter. So I don't think you could use an RB20 flywheel with an RB25 pressure and clutch plate, not without machining anyway.
Change the lot all together though and there are no problems.
Hope that clarifies further
I was looking at bot gearboxes today and i removed the speed sensor from the rb25 box and it was very long, about 4inces, then looking at the rb20 box the sensor is more towards the back of the box and i could not be any longer than about 2inches, i couldnt take it out as i would then have to replace the oil but i just wanted to know if there was any special trick to swaping them over as the rb25 one is long with a red gear on the end and it appears to be all in one piece.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
