hey guys just after some advice,
I do not like looking at that MASSIVE Factory nismo spoiler on my r34 gtt coupe (the wrap over) :rolleyes:
Been thinking of removing the thing... does anyone have any advice?
Cost, level of work and maybe a place that does it?
cheers
https://www.sau.com.au/forums/topic/172229-removing-that-ugly-spoiler/
there are a lot of bolt holes if you remove the spoiler, I asked around about welding and leveling the holes, quite expensive.. I think asking over $1k
Ohh mann.. what the hell is with these japs and massive spoilers!! loll there i was thinking wen i bought it ohh yehh its not a big deal it'll pop off
cheers, anyone else please?
that's a load of crap, over $1k my arse.
But look, the reality is you will have to get the holes welded again then the whole boot will have to be repainted.
Here's the drill - to repain whole boot you will be looking at at least $300.00, welding should cost around $100.
Without further details on whether you want to go wingless or install another wing - I can only assume you will go wingless - if this is the case, then you you will be looking at around $500.00 max for this exercise.
On the other hand, if you want another wing - then of course you will have to buy one (price depends on the wing) then get it professional painted which will be another $250 or so, so yeah.... that's it in a nutshell.
Actually, talking about the R34 Nismo wing... I actually have it on my r33... I have a drift wing on it, then a bit further in, I got this wing without the wrap-around, looks aggressive as.
I would suggest that you take the wrap-around off and just leave the wing on it's on free-standing - looks aggressive as - but yeah, I would also move it in a bit, it's sticking too much towards the end of the boot which makes it look awkard.
good luck.
HAHAA yeah i heard that once from someone!
Yeh well sounds like the side things will have to go, would repainting cost a fair bit for the rear sides? how much would i need to paint there?
Bro, if you shop around you should be able to do this under $800.00. You gotta shop around bro.
Good luck.
Were you at Thornleigh maccas when you heard it? cause thats the last place i said it :)
t
good luck.
Can I see a pic? I'm intrigued!
i removed my wing
got small plugs to fill the holes
cheap and effective
wing on
wing off
wing on
wing off
Are we talking about the same wing here?
Coz the R34 altia wing or nismo wing has about 7 gaping holes on the rear quarter panels where the corner parts of the wing are fixed...
ADZR34: I was thinking exactly the same when I bought my car... not a problem, I'll just take off the corner parts when I get home. Man did I get a rude shock!
The best quote I've got so far is $600 to take the corners off, $900 if I wanted the centre piece off aswell. That's to weld the holes shut & repaint the whole area. I'd have had it done already if not for getting my rims, & Intercooler first etc.
The scary thing is, the wing is actually starting to grow on me lol I'd better get it done soon before i start liking it.
Everyone at my work had the same reaction, they thought it was hideous but now they like it :)
Everyone at my work had the same reaction, they thought it was hideous but now they like it :D
Exactly! such a shock for me LOL.. bastard wont come off..
oh well see i was thinking, here guys help me out... if i remove the whole spoiler off and swap it for the standard one will the holes on the boot match up and screw to fit the standard spoiler??
and one more thing where did u get that qoute for $600?? pj
lol I got the bastard off eventually, just left 7 Humongous holes in the quarter panels.
Spoiler part on the boot should use the same bolt holes. Car companies like to make interchangeable parts to save money
Quote was from extreme bodykits in Wetherill Park Sydney, $600 for just the quarter panels. $900 to remove the spoiler aswell altogether.
Although he did the bodykit on my old R33 so he gave me a better price than usual.
Edited by Yo-Yo
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
