ive got a series 2, but i thought it still needed cutting?
what power is the arc 105mm core good up to?
Im pretty sure but not 100% that no cutting is required. my mate was thinking about replacing his front bar with a series 2 bar cos it didnt need cutting. he didnt end up doing it cos of family stuff
https://www.sau.com.au/forums/topic/172288-smic/page/2/#findComment-3174857
14 will be safe, if your has the supporting mods.
AS for stock turbo untuned, you will get more response and power by running less boost.
Just because you run 14psi doesnt mean your car will going any faster.
Run 0.8 bar max.
That is 10psi.
I can gurantee you the responce will be much better with lower amount of boost.
Once your car is tuned to run a little higher boost then go for it.
Get a 34 side mount, which can handle up to 200-210kw.
ARC are to pricey. 34 cooler will do the job fine.
Why would a car running lower boost be more responsive than a car running higher boost? Do you mean to say a stock turbo with a max 10psi will reach the 10psi faster than a stock turbo running 14 psi would reach 10psi? Or do you mean to say the turbo running 10psi will seem more responsive because it has a lower max boost and therefore reaches it quicker than it would reach 14psi?
https://www.sau.com.au/forums/topic/172288-smic/page/2/#findComment-3175137
For -- (stock ecu, turbo, smic)
1) you car will be running rich firstly.. Every skyline does!! lol
2) You will see more flat spots with higher boost levels..
3) Running high amounts- your plugs may foul up.. So you need to regap the size.. to make up for it..
4) From personal experience and seing it from friends car, when they first started.
5) on a hot day, having that bit extra psi or so wont help you at all.. Car will feel slugish when you really push it, more so with higher boost..
Im just speaking from experience, and i maybe im wrong.. Your car may act differently..
But i found that running that bit less boost, made my car more responsive.. ie i turned it down from 0.8 to .7 bar
FACT: At the drags.. Im like lets run more boost.. at 0.8 i got like 14.5 at best for 3-4 runs.. A guy suggested to me at the drags to turn it down.. so i did one notch.. got a best of 14.0 flat..
BUT who knows, maybe my reaction time was just better...
Maybe others can back me up on this?
either way my car feels better runnin a bit less boost.. that is 0.7-0.75 bar.. I felt no flat spots at track day..
and i still got stock ecu, turbo and smic..
i noticed you posted in that 34 wreck thread from some time ago, the guy was selling his cooler for 80 bucks. did you end up buying?
rang him the night before to confirm meet up.. he goes his dad ran over it?? hmmm
250 does seem pricey.. But they normally start at that price and drop down.. to 150-200
Cost that much because they know its a cheap upgrade for the 33..
on a side note, what is everyone's opinion of china cores?
Very good coolers.. They do the job.. 0-300kw.. has been proven..
Many threads on this topic..
Cores are all the same.. Comes down to which copy has the better pipings..
AS for cutting the bar on the s2, i will confirm with you tonight. My friend does cooler installs.. So i will ask him about the series 2..
Otherwise im sure there are heaps of members on here with s2, with fmic..
Edited by siddr20
https://www.sau.com.au/forums/topic/172288-smic/page/2/#findComment-3182066
i was at Bel Garage one day when they were isntalling a JJR fmic into a R33 s2. they said that if you do it right then you wont need to cut anything away ie fan baldes, front bar..etc..
i have an Apexi front mount with same side return piping which costed an arm and a leg which didnt need hacking either. small core but does the job easily.
https://www.sau.com.au/forums/topic/172288-smic/page/2/#findComment-3182097
well ive actually helped a mate install a just jap front mount in his series 2 skyline, this was a few years ago and im 100% certain that we had to cut some of the bar ( on the bottom of the hole under the 2 lights in the bar) because the piping was hitting against and we couldnt put the bar back on. not sure if anything else had to be cut.
But wen we finished it looked very neat, and you couldnt tell we cut anything
https://www.sau.com.au/forums/topic/172288-smic/page/2/#findComment-3182138
to all the people that said they'd double check, any confirmations that its possible to install a fmic with absolutely NO cutting?
SiR RB: Id expect Just Jap, like other generic core/pipings, to need bar modifications but a brand name cooler might not.
Edited by ak_stylez
https://www.sau.com.au/forums/topic/172288-smic/page/2/#findComment-3185207
I just fitted an R34 intercooler to my series 1 stagea. It cost me $80. Bunged it in on the weekend. There is the obvious difference in size but also if you examine the cooling fins they are perforated on the R34 intercooler meaning greater surface area to volume ratios for heat transfer.
It has all the power headroom I need for a 220awkw-ish turbo upgrade. I am also going to run a set of cams in the motor later on so the average power will be significantly up adding to the potential heat load but, I am completely unconcerned about heat soak and the abillity of the R34 intercooler to do a decent job. A water spray kit gives me everything back I might lose on a sustained flogging and costs bugger all to make.
You can skin a cat lots of ways. The R34 intercooler is a good stepping stone till you make your mind up about the actual power goals and how much money you don't have to spend on other important supporting mods.
Edited by rev210
https://www.sau.com.au/forums/topic/172288-smic/page/2/#findComment-3186361
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
