looking for the part number / numbers for a R34 RB25DE neo ECU.
We have put a NA RD25DE NEO in a R31 and in moving from shop to shop have lost the computer so i need a ECU. can it going is a manual.
so auto or manual ECU numbers will be fine...
so far i can get a
23710 AA110
MEC 05-030 D2 8608
any help would be great
Edited by sir31
Hey all,
Have searched this thread high and low - couldn't find this part could only find GTR:
RB20DET Power Steering Belt. - Anyone know the number ?
Thanks,
Can anyone please tell me the part number for
oem gtr r34 boot spoiler / wing?
I need the complete part number (wing stay and the wing itself)
cheers!
part No. K6030-AA104 should get u out of trouble
so far i can get a
23710 AA110
MEC 05-030 D2 8608
these should help. all based off a RB25DE 2WD.IRS 5MT
05/98 - 07/98 23710-AA100 / 2371M-AA100
07/98 - 11/98 23710-AA102 / 2371M-AA102
11/98 - 23710-AA103 / 2371M-AA103
original No. / superseded No.
OK THESE ARE FOR A MANUAL..
CAN WE CONFIRM THAT THE
23710 AA110
MEC 05-030 D2 8608
I CAN GET HOLD OF IS A r34 rb35de neo DAM JUST NOTICE CAPS SORRY.......
Hello everyone,
I made a thread in general maintenance but no one replied so far so i thought i'll ask here.
I'm looking for the exhaust valve part number for a RB25DET series 2 r33.
I've looked high and low on the internet and cant find it, hope you guys can help a desperate fellow out.
cheers
can anyone help me?
its for R34 GT-T
- RB25det neo Nissan OEM Main stud
- RB25det neo Nissan OEM Head stud
- RB25det neo Nissan OEM Piston Rings (86mm)
basically all the rebuilding parts except gasket kit.
thanks.
anyone can help mee?
Edited by putraged
23710 AA110
MEC 05-030 D2 8608
that ecu suits 05/98-07/98 2wd IRS RB25DE 4AT
Hello everyone,
cheers
Part No. 13202-08U01 suits all R33 RB25DET engines
i think the reason why u don't have a reply is your request is to broad and poorly worded
for example Main stud an Head stud??
do you need head studs for the manifolds or do u mean the head bolts?
main stud i would be thinking the studs for the main bearing caps
and genuine does not list the size of the rings in "mm" only in Oversize from std e.g. .5, 1.0
if u can explain things a bit better i can help u
Hi guys, just wondering if anyone can get the part number for the R32 GTS25 boot sticker? Dont know if there are different colour stickers depending on the paint colour but Im after the silver sticker..
Cheers
-D
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
