hi guys, I just bought a R32 GTS4, its got a pod filter so I want to box it up.
does anyone have some examples of designs they could show me? especially for intake.. i don't really want to cut any holes in my chassis/wheel arch if i can avoid it.
the cars at the mechanics at the moment so I can't measure it up, but i was just planning to do a 4 sided box sitting against the chassis with a 3 inch hole in the front to run a piece of pvc pipe or some form of tubing out to the front bar. where do people usually get the air from? does anyone have pictures of the stock airbox so i can see where it gets air from?
I work at a fabrication shop so i probably have access to anything i would need.
https://www.sau.com.au/forums/topic/172970-help-fabbing-airbox-for-r32-rb20det/
Im in the process of knocking one up for mine at the moment, should have it finished next weekend so i will post up some pics and what i used :whistling:
If you don't want to cut any holes you will probably need to use the stock hole under the headlight.
You can get an r32gtr or r32rb25 intake snorkel, which uses the all of the stock hole unlike the factory rb20 snorkel.
Also you can take the nose, that the snorkel fits onto, off your factory airbox as it is made of metal and rivet it to the front of your new airbox in a position that aligns with the factory snorkel.
It's up to you if you want to use the gtr/rb25 intake piping that attaches in front of the snorkel.
I've thought about using the gtr/rb25 intake section that bolts to the front bar reo and blocking off the intake hole and then plumbing an air scoop into the fitting that used to go to the gtr/rb25 resonator chamber.
The thing I wasn't sure about was whether the resonator duct was big enough.
Yeah pretty much what i had in mind myself, engine going back in this weekend so hopefully finish off the box while im at it ;)
  • 3 months later...
here's an example of my crappy diy for the time being. need a nice 3" pvc pipe but got this one for free, so cant complain.
in the process of fibreglassing one for mine. I've got a plug, now I just need to make a mould and then lay up some fibreglass on it. Will post a DIY with pics when I'm done.
oh and ive got a front mount so there is one spare hole where the pipe work normally returns to the engine so i used this as my air feed from down next to the bliker in the front bar , ive used that flexible tube from super shit AKA super cheap , the stuff the streaches then stays where u leave it , its great stuff
i made one those covers but came to the conclusion to put my pod outside the car i relised that it sucked way more cooler air just thought u like to know
i also have 32 gts4
Edited by ACTIV32
I think the std airbox with K&N and the triangular metal entry pipe beaten out to cylindrical,
inside a five inch plastic duct molded to fit into the entrance along side the headlight is the ultimate.
In the pic above ( post #7) you can see the two rectangular holes near the headlight,
- cut the middle bit of metal out making it one HUGE opening for the intake plastic duct molded
to the same shape and protruding out a bit and wrapping round to make a smooth air path!!
if ur after ideas for an airbox heres mine, on a r33.
2pieces of allie. top of one is press bent. then small rivets hold on threaded fasteners, so screws can go on top for ease.
i also have the box lined with heat resistant, and reflective foam. works a treat
Edited by r33cruiser
im having trouble thinking up a heat shield design for my r32, the pod is basically sitting upright because it has to fit between the cooler pipe and the a/c pipe i think it is. and im not to keen in extending the rubber intake pipe due to keeping things as short as possible for response purposes.
does anyone else have this problem?
any pics to show a design someone has come up with, to counter this problem and still keep things cool?
cheers
cheers
I'll get Sl!m to post pics of his airbox in here.
As for shorter piping from the pod to the turbo - this is not going to affect the response of the motor.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
