Hi All,
Well my clutch booster was leaking, causing the old un-even idle issue etc so i needed to replace it.
Contacted Nissan and the genuine R33 GTR Clutch booster cost around the $600 mark.
I found out that Repco are able to source an identical Nissan genuine part for $215 delivered. Both the faulty factory booster and the one repco supplied are identical but the part numbers are different.
The new Repco supplied part number is 300630-05U01. Repco's internal part number for the part is the same as this without the "-".
Cheers,
Ian
Edited by Vspec R33
No i didn't have them check up on that. It might be from an R32 GTR, a patrol, or a 300zx. When I started researching the part these were the other nissans that I found also used boosters.
I'm just glad I didnt have to give nissan another donation. This allows me to do the complete redline fluid change on the GTR without denting the bank balance quite so much.
Cheers,
Ian
Hi All,
Cheers,
Ian
I bought one from Nissan a while ago for about $150, just the booster not including the master though.
What's a clutch booster?
You don't have one in your car Adam, all GTRS have them , Just like brake boosters, less effort to push it down .
Landcruisers have them in some models but they use 2 heavy springs for assistance now ( done away with the booster ).
I was just going to put a slightly larger slave cylinder in my car to lighten the clutch. Maybe I could put a GTR booster on?
Too hard
You will need to recess the fire wall 40mm for the booster and mod your clutch pedal
Nismo make a larger slave for a lighter pedal
Don't bother , use the larger slave and it will give you better feel , the take up point will be less sudden.
or just do leg press on the left leg alot more at the gym.
05U in the part number denotes GTR, it probs is for a GTR, Nissan just have some whacked prices sometimes like the front bar lip is $400+, but a head gasket is $52. They are all over the shop.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
