"Are you ready for two full days of events, great food, excellent location, a spot of wine and catching up with all our members – miss the extravaganza at your peril !!
The fun starts Saturday 26th July at the Twin Service stations at Paruna (just north of Ourimbah) at 10am with the Touring Road Event. During the day this will include a Hillclimb at Ringwood and the day’s competitive activities conclude at approx. 3pm after the sprint event at Cessnock Aerodrome."
This sounds like a great event. I believe Dan mentioned it at the meeting on sunday. All the information I have for the moment can be found on page 7 of the CAMS Tale Spin newsletter here.
I intend to do the Saturday events and then cruise back, missing the dinner.
I'll post more when it becomes available.
Who's keen?
ps. We'll all need Level 2S licenses or higher for these events. :rolleyes:
Sounds good to me too. (and Kel, as always :P )
Dino, have you or Dan been in contact to get more info as it comes out?
Just a warning, we will probably require extinguisher in car and a bonnet tie down. Will need to see supplementary regulations to be sure.
They are just sorting out some details. It should only be a couple of days and the regs. and entry forms will be out.
Go here for the Safety Requirements. These are a bit tighter than the drive day standards and scrutineering is more in depth. :)
OK - this is cams requirements:
Compulsory vehicle and safety requirements include:
+ A secondary bonnet restraining device rope or strap is OK
+ A fire extinguisher I got one for about $50 from Race and Rally, mounted in bolt that holds back seat on - no holes required
+ A blue triangle indicating the position of the battery Either buy a sticker or just use blue electrical tape
+ Headlights covered with a transparent adhesive film (i.e. Contact) mmmm....i didn't do this one, if required the old cross of electrical tape over lights can do the trick
These can be applied to road going vehicles with a minimum of difficulty, and usually with no permanent modifications.
Competitors are required to wear:
+ Non-flammable clothing from neck to wrist to ankles
+ Helmet
+ And are recommended to wear motor sport specific gloves and shoes.
Basically the same as regular track day requirement for clothing
As Cams say, you can get the bonnet tie down and extinguisher in without having to modify the car, so its not as difficult as it may seem.
For the taping of headlights, I'll be using clear contact sheet cut to the shape of the headlights. For this event with a drive between the hillclimb and the sprint it'll save pulling the tape off and doing it again. :D
Understand bonnet thing..........................
understand fire and triangle things...........
clothes - helmut - gloves...........................
BUT
Originally posted by red900ss
........ We'll all need Level 2S licenses or higher for these events. :( [/b]
in s'tralian this would mean what?
Bonkers,
The licence that Dino is talking about is a racing licence that Cams issue. cost is approx $90 I think. It is required for events that are run under/by Cams that have competition invloved.
For more info go to www.cams.com.au
Dan.
  • 4 weeks later...
C'mon all, heres a great chance for the club to make an entrance into the CAMs scene.
Its got it all:
Cruise
Hillclimb at ringwood
Motorkhana (mini dorifto)
Big dinner
Wine tasing
Weekend in the hunter
and not to forget, the commemorative t-shirt :)
And as long as we get 4 cars entered (=8 people) we can go for the club prize.
So who else is in?
Hiya FLIP, it's just a matter of filling out the form (goto www.cams.com.au and click on Licenses) and sending of the money to Melbourne. However, there's probably not enough time between now and the weekend.
Come out to Eastern Creek on thursday instead (no cams license reqd). :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
