Hi all.
Just briefly, post up whatever is relevant.
This isnt a section to talk about upcoming models, rather models that are already out :(
If people have and ideas, sticky threads, info threads, whatever they want to create.
Let me know and we'll work something out.
Cheers
Ash
woohoo about time we had for the current model skyline.
They are an awesome car and will hopefully be what i'm in next.
The quality is leap years ahead of the R34 and anything before hand.
Thanks Ash,
Could someone go through the other sections and find all the v35 related stuff and put them in the v35 section, because there were a few helpful threads reguarding sat nav conversions and such.
Cheers
Thraso
I cant do a bulk move unfortunately.
But if someone finds a thread, just drop me a PM.
I generally only check PM's once a week, so be patient, i will move them if you send me links etc :thumbsup:
cheers!
  • 3 months later...
Would we be stretching the friendship for our own for sale section too? :)
I know its a long shot, just thinking what would be the best way to sell parts specifically to other v35 drivers.
The other thing we can do which is probably a bit more practical is still post in the For Sale section but we use our own naming convention for the threads. Eg, start all threads with something like "V35-". If we all agree and make it the policy for selling our parts, then we can have a sticky up the top that runs a search that would pull all the threads for V35 parts and present them to us. Even if it was just a link to search results that would be fine. But we have to all agree on a convention.
Thoughts all?
We are re-doing the For Sale stuff currently, you'll notice there is a pre-filled out post every time you create one and so on.
We don't really want to create any more sections as For Sale is hard enough to police now with 3-4 people doing it on a mostly daily basis.
The state sections have been touch and go in Admin discussions for months.
The main reason is scammers. The more spread out sale areas are, the less chance Admin are going to see/pick-up on dodgy people via our various methods. This in turn leaves a bad taste in members mouths, even if its not SAU's fault, and last thing we want is people to be ripped.
So thats sorta the reasoning behind it all.
If you guys always put "V35-" at the start, then you'd easily find it via the search if you did things that way.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
