Hey guys,
Couldn't find anything about the G-Tech performance meter on this forum.
My question is, do these performance meters live up to the hype?
I'd really like the opinions of people who have one and have compared things actual power, 1/4 times and torque to the G-tech values, rather than 'I have a mate who has one of these and says...
Here is two different models I'm considering buying:
http://cgi.ebay.com.au/G-TECH-GTECH-PRO-SS...bayphotohosting
http://cgi.ebay.com.au/G-TECH-PRO-RR-ONBOA...1QQcmdZViewItem
Cheers.
https://www.sau.com.au/forums/topic/173102-g-tech-performance-meter/
the g-tech i have is a little older then those and not as many features. they are a very good indication but not 100% accurate. also not recommended for the street as there is very high speeds involved when dong a 1/4 mile pass :D
isn't that what the strip's for?
Yeah, I meant just more for launches and stuff. I've got a 110km/h road near me that sees very little use, so I can accelerate up to 110, which is good but I've got no way of monitoring performance. The closest drag strip to me is an hour and a half away so I don't get that many occasions to get down there. I'm not looking to piss people off with idiotic story's just trying to determine if the g-tech units are worth the money.
Cheers for your response, do they actually give a good indication of HP?
Ive got the last model,
Handy little unit, very consistant and i think its supposed to be accurate to 1/10th of a second or something.
Regardless of its accuracy compared to the track, its good to compare results between mods.
Take it for what it is...a good little performance indicator, but its not the be all and end all.
There are a total of four different units.
The cheap ones you see on EBay are the oldest.
The RR & SS models are the most recent.
I have an RR. In short for the money they are very, very good. They can accurately give you a quarter mile time & at the same time via the downloads allow you to see (in the comfort of your lounge room) which rpm launches worked best. When used on the circuit they can allow you to pinpoint the effectiveness of different modifications you may have made to your car. I would thouroughly recommned them if you want to dip your toes into the cheaper end of the data logging world.
Oh and don't bother buying the old, cheap ones. They are nowhere near as good.
Edited by djr81
I've got one of the new G-Tech SS' and its quite good. I find it reasonably accurate (G-Tech time vs stopwatch time), but I mainly use it to measure lateral G's. ;)
I'm up to 1.23G's on 17" RT215s, and 1.29Gs on 18" D02G's.
Thanks for the last few responses, very informative. I've decided to import a ss unit directly from G-Tech.
To be honest for the extra coin I would recommend the RR.
You can log & export data & then use it how ever you like. The attached image shows a gain in both balance & lateral grip. Obviously the circuit is anticlockwise.
Edited by djr81
  • 6 months later...
  • 4 weeks later...
I'm also interested in picking up one of these...but not for timing or drag info, more so, i'm after one to log information pre and post modification, so i can test certain equipment and see if it makes any sort of a gain/difference without having to 'feel' for it. Sometimes one may be overcome by the money they've spent on an modification, that they believe that it really DOES make a difference, when it doesn't...is this performance measuring tool accurate in terms of, Power and Acceleration?
Cheers,
Cartz
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
