I've asked this in other threads but haven't had any luck as yet.
I have a bit of reversion from a high flow turbo.
One of the things I notice on the map trace if you hit it in 2nd (or any gear >1st) and then back off - i.e. rev to about 4 or 5k and then back off the fot doesn't go straight back to the top - there is a slight delay. THen when it hits the top It shoots back down the vertical axis for a second or so even with the throttle closed.
Anybody with stock or other turbo - have you noticed this?
Also going up a hill in 4th gear hovering around 0-3psi you can see the dot flutcuating between about 3 or 4 load points in the vertical axis with a steady throttle opening.
Thanks
https://www.sau.com.au/forums/topic/173278-map-tracer-query/
  • Replies 62
Posted Images
I know that!! I am trying to troubleshoot a particular problem
What I suspect is happening is the turbo is delivering too much air and flow reversion is occurring where the engine can't consume all the air.
Most of the time at lower loads (in load points 2-6 I can hold the dot in the same box going up a hill - i.e. hold the same load). As the load increases I feel the turbo may be spooling too - as you go up to load point 9 etc in4th gear the AFM voltage is fluctuating a lot!
Can anyone answer the questions I posted and check their map trace.
I don't think what I described is normal but I never checked it that closely with the stock turbo.
Edited by benl1981
Yes, It sounds like you are experiencing fairly mild compressor surge (it must be mild if you can't feel it, only see it on the map trace).
I haven't watched it in that situation, but i have logged my afm voltage before (when i had no bov) and watched the numbers bounce around all over the place when i lifted the throttle. In my case, basically, big spike, down to nothing, not so big spike, down to nothing.....you get the idea.
I can get mine to chuff away quite happily in similar situations (partial throttle, up hill), though generally 3rd gear, 5000rpm or so.
Sometimes I can definately feel it - but that's when it jumps about 5 or more cells in one hit straight down the vertical axis.. So with the BOV attached did you still get a similar effect.
What spec turbo do you have and on what engine?
Cheers
Edited by benl1981
Ben, I'm not sure of the specs on your particular highflow, whether it's the same as the current gcg. Nor do I have a powerfc, so I can't comment on the map tracer.
If you fit a pod filter on and when you're flooring it, do you hear flutter as the revs are rising? not when you take your foot off. How bad is the compressor surge?
As I mentioned in your previous thread I've seen and experienced it on stock turbo'd cars, highflows and GT35r's with and without a bov.
Without a bov it is much more severe; with the factory recirc it only occurs under specific circumstances; you can drive around it easily.
From my understanding of your problem it isn't so much compressor surge but rather the air travelling backwards through the afm, so reversion as you say. But yes.. There is compressor surge in there but its not the compressor surge causing the drivability problems but rather the air hitting the afm be it via the dump of the recirc bov or the air travelling backwards through the turbo and out past the afm.
I've found running no mesh on the turbo's side of the afm does slightly increase this reversion so to speak.
The fix from what I've found.....
1. Drive around it/change your driving style - This is the big one.
2. Atmo Bov (but you then have overfueling stalling as a result)
3. If your running no bov reconnect the stock bov to reduce the intensity and frequency of the afm reversion.
4. Larger dia. afm to turbo pipe or if possible longer.
A 4" afm to turbo pipe appears to work well in reducing this afm reversion.
To try and reduce the reversion in the AFM, you could build an anti reversion cone into the intake pipe. Im going to do this on my gtr with these pipe sizes
____________
____________ / : : \_______
____/ : :
Turbo 4inch 3.25in : 5inch : 4inch Air filter
____ : :
____________\ : : _______
\__:________:_/ The AFM is in the 5 inch bit, so i helps that im running a 5in AFM
The : is mesh(like the standard stuff except thicker)
____________
____/ : :
____ : :
It may work - could also compound the problem via increasing the air speed as it necks down to the AFM. Whats to say it wont cause reversion as you back off ie in stead of the turbo and engine inducing the air in it reverts off the 3.25in section. You could do what the EF falcons do via introducing a helmholtz resonance pipe on a particular bend. different theory but it should work.
Ben,
Its possible. All though I run a stock airbox with a 100mm cai I don't see why you couldn't run a larger afm->turbo pipe on the rb25.
With the larger afm->turbo pipe + retaining the mesh on your afm + retaining the stock bov + ensuring you haven't blocked up the bov's bleed hole the reversion is basically non existant apart from a few select driving conditions. That was a mouth full.
Yours may be a little more touchy I'm not sure but...... (<<< Lots of dots for those who care lol)
You obviously know how to get it to do it... Have you tried to adjust your driving style to prevent it and just accept the fact that its part of owning a modified car? :mrt:
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
