my car is tuned for 100 octane but i want to run something with higher octane this saturday at the drag meet for extra protection.
i rang martini fuels in rowville and got quoted $145 plus GST for 20 litres of 110 octane fuel. this is rather expensive so i called moorabbin airport to see if they still sell to public like they used to back in the 90s when i was a regular buyer... the avgas is currently $2.35 per litre and with 106 octane seems much more economical.
they still do sell to public only if a cams passbook ( as he put it ) can be shown at the time of purchase... i assume this is what the track guys with cams licenses have???
just wondering if anyone is also interested in runing avgas and or can help me purchase some with the help of their cams passbook please...
i can take care of all the logistics if needed..
cheers
https://www.sau.com.au/forums/topic/173443-avgas/
I wouldnt be using avcat/avgas.
Your better off using a correctly designed fuel if you want any piece of mind.
You'd only need to mix 10 litres of martini/sunoco to a 3/4 full tank if all you want is protection.
You could then save the stuff for another time @ Calder or whatever.
Or alternatively if you wanted more use out of the fuel and have a PowerFC, that can be easily sorted via some quick injector/ignition settings
I think the Sunoco was $120 for 20 litres, and is 104, unless prices have changes (VPW)
https://www.sau.com.au/forums/topic/173443-avgas/#findComment-3188238
any reason why avgas no good??
i do have PFC but too much of a noob with it to play around with Benno's settings..
if you are confident and know what you are doing and wouldnt mind, it be great if you could fatten the curve with 110 octane mix 50/50 or like you said add to 3/4 of v-racing... if the gain is considerable i dont mind paying 145 for 20 litres, as long as you can put the settings back to what they were...
https://www.sau.com.au/forums/topic/173443-avgas/#findComment-3188287
from just one tankful?
I thought a tankful here and there didn't really effect anything??? Thought about/tried using a toluene mix? Also food for thought the military spec avgas, I can't remember it's name of the top of my head but it's 140octane, they use it in some of the warbirds and the caribu's etc. where to get it though I dunno.....
https://www.sau.com.au/forums/topic/173443-avgas/#findComment-3188326
thats what i thought too that one tankful wouldnt hurt..
anymore info on toulene mix.. where to buy, how much to mix, how much cost and how much does it boost the octane??
might do some search on toulene..
https://www.sau.com.au/forums/topic/173443-avgas/#findComment-3188336
a couple of points. avgas is no longer 106. more like 102 or 103. also, a cams passbook is a special fuel permission book, not a cams licence. to get one you need (from the top of my head) a PC or NC licence, and a cams log booked car (to use the fuel in). the write in the book how much you buy etc to prevent abuse of the system.
edit: as ronin suggested elf LMS is a better option, and is unleaded, and does not require a licence and passbook to buy it.
https://www.sau.com.au/forums/topic/173443-avgas/#findComment-3188857
Octane isn't the only measure of a fuel when you're after some protection for a track day. Some of the very high octane unleaded fuels will burn very rapidly compared to pump fuel and could result in a lean AFR. Motec's website has some very interesting fuel test data comparing avgas and v-power racing from shell.
https://www.sau.com.au/forums/topic/173443-avgas/#findComment-3188944
Jetdat
If benno has set your tune with V power racing then don't touch it and race it with that fuel in the tank.
It will be fine.
I ran my car around sandown with his tune on vpower racing and the knock levels were fine all day.
Your engine has been tuned with the fuel characteristics of v power racing, don't go putting a higher octane rating fuel (even if it is unleaded) as this fuel will exhibit different burn characteristics etc
https://www.sau.com.au/forums/topic/173443-avgas/#findComment-3188994
I agree with Beer Baron. I work at Moorabin Airport and can get some for you but you may aswell just run V racing at 100 octane because thats all avgas is. If you want to go faster you'd be better off just pullling the rear seats out and not worrying about the avgas. That about all you'll notice. Nothing. There used to be a few different types of avgas but 100 is all you can get these days easily/common.
Avgas is just wank that people think it gives them heaps more power but its just in their mind compared to 98 octane or v racing.
https://www.sau.com.au/forums/topic/173443-avgas/#findComment-3189003
Avgas is not Shell V Power Racing. They are completely separate animals. If your car is tuned properly, don't worry about it.
Obviously their not the same but are the same octane rating. He doesn't run avgas in it at the moment so there is no need to run it and their not really completely separate animals.
https://www.sau.com.au/forums/topic/173443-avgas/#findComment-3189459
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
