  • Replies 121
235 on 9" and 225 on 8" i find to be a pretty good combo. im running a 225 on a 8.5" at the front and a 225 on a 9.5" at the rear and i find it pretty good for drift, rear end is very predictable and front doesnt have much stretch which means it grabs the road well and is good for control without being too floppy for the longer corners where the front slides heaps as well.
ok ok....
im getting confused too...
so tis stretch tyre thingy is tis good or bad?
i know stretching the tyre is to prevent it from rubbing on the fender. so will it cause the tyre to worn off unevenly?
izit legal?
grip wise/traction? no point buying good rubber for the grip and traction.
ok ok....
izit legal?
Did you read all the thread?
  • 3 months later...
Just need to ask a question about tyre stretching, and didn't want to make a new thread just to have Nismoid tell me to search :P
I currently have 245 semi slicks lieing around, and 265 rims... I need some drift wheels...
First question is, will that stretch? (i assume it would, but I don't remember the profile of the tyres, they are probably 50s off the top of my head)
And is it even smart trying to drift on semis?
Thanks guys :D
o.....k.........a 265 will fit on a number of different sized rims so find out what it is in inches
For example ive got 235's on a 9.5, and also 265's on a 9.5. But that doesnt make it a 265 rim, it makes it a 9.5rim
A lot of Commodore/Falcons 17" inch rims run 235's so it easy to find still pretty decent tyres at my local tyre fitters to use at pratice days when you can't afford/don't need new tyres.
I wouldn't really call putting 235's on a 9 (what i run) stretching though but i know of others who run 235's on bigger rims because they are so cheap to buy good new tyres unlike 255's etc that can cost quite a bit when a small town tyre centre have to order them in for you.
But that could also be another reason (if it hasnt been metioned) that people stretch them...
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
