Need to get my stock 32 turbo off to replace with a similarly sized 33 hi-flow. Is it possible to get the turbo on & off without removing the manifold or is this a must? Want to know if I need a manifold gasket because this will be getting done at home over a weeend. Want everything I need prior to removing anything. Yhank you
https://www.sau.com.au/forums/topic/173881-removing-32gtst-turbo/
You can easily take off the turbo without manifold coming off.
Its 4 bolts, couple lines off, and turbo is out.
I would however advise if your going to do it... to change manifold gasket. But REMEMBER... you WILL break manifold studs. So be prepared to replay/drill out a few.
If you dont know how, then i'd probably just pay someone.
Easier :(
I replaced all the manifold studs about 6 months ago while fitting a dump pipe & replaced the gasket then so dont want to do it again unnecessarily. Removed turbo & manifold as a whole so wasn't sure about splitting them in the car. Mechanic by trade mate, so replacing studs is no problem... Just dont get to work on Skylines etc. quite as much as I would like... Thanks for your help
If you've done the studs, then no worries.
No need to change them or the gasket now.
Just swap out the turbo.
4 manifold--turbo flange bolts
Oil/water lines
Oil return line
And it should pop out if you remove all the surrounding piping.
Turbo off with manifold on poses no real problem. Also i'd replace the banjo bolt washers while your at it.
Its pretty straight forward, much easier than taking manifold out as a whole.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
