Its time to upgrade my brakes and have been looking at the various brands.
I have had DBA slotteds on my last car but after a year of driving i found that the rotor was wearing pretty bad.I was using Bendix ultimates at the time.
I dont think ill be getting RDAs.
I was wondering if anyone has been using the SCR rotors from Project Mu for a while?
Im thinking of getting those with Ferodo 2500 pads.
There seems to be only one line of slotted rotors from Project Mu for the R33 gtst which is the SCR line.
I would like to keep the budget at 1k so i wont be getting alcon or brembos.
https://www.sau.com.au/forums/topic/173886-project-mu-scr-rotors/
There seems to be only one line of slotted rotors from Project Mu for the R33 which is the SCR line.
Have a set of them on and have about 3 months and a couple track days on them. No complaints - love em.
I have the scr pros on my 32gtst. Great bit of kit. Worked well at Wakefield the other day as well. I also run Pmu 0-800 pads (HC+?)
Admittedly, i think the rotors are overkill for my application but i just couldn't pass them up. scr's would work just as well.
I think ill be going the SCR rotors matched with the Project type NR pads.
It says on the project website the NR pads are only sold in japan.Luckily Greenline sell them :rolleyes:
Been running Nismo S tune pads. Great pad - stop great cold on tha street and don't fade on the track.
What diam rotor? So they are the alloy hat rotors? Can i ask where you got them from? Im hunting aroudn for some rotors and pads.
Im running r34 GTt 310 rotors and calipers. Yes, the alloy hat ones. Mine came from mu secret in kensington though they moved recently to somewhere on parramatta road.
Dave, anything with the name project mu on it is pretty good as an understatement.
I have a friend with an r32 with the project mu pads only on stock rotors, and the difference compared to the stock pads was phenomenal!
As much as i'm sure rda/dba are an ok product, I feel it's like comparing holden with nissan.
Not to mention, nowadays with the jap resellers like greenline,a nd also with our high dollar, the price difference is not a lot!
Edited by MANWHORE
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
